Crankshaft ID ???
- teamcow
20 Aug 2012 14:42 #543644
by teamcow
teamcow550@aol.com
Crankshaft ID ??? was created by teamcow
How can I identify the different Kawasaki Z1 cranks and rods? Is there a difference in them? Thanks in advance for any and all help.........
teamcow550@aol.com
- OldSchoolZ
- Thank you received: 33
20 Aug 2012 15:06 #543651
by OldSchoolZ
Remember, don't work on your bike so much you never ride it.
Replied by OldSchoolZ on topic Crankshaft ID ???
Z1 parts should all be the same. They had same bore, same stroke....same.
Z1 was referred too as 73-75. They started calling it the KZ900 in 76 I believe.
- APE Jay
- Banned
- Thank you received: 58
20 Aug 2012 20:20 #543722
by APE Jay
Replied by APE Jay on topic Crankshaft ID ???
The ones referred to "porkchop" cranks because of the shape of the counterweights, are Z1s. The KZ1000 cranks have round counterweights. Both have 15 tooth cam chain sprockets. If it has round counterweights and 16 teeth, it is a MK2
