engine trouble?
- 67637454
13 Aug 2012 20:21 #542381
by 67637454
engine trouble? was created by 67637454
I just bought a 1984 kz750 last week. It is my second bike, my first being a 2009 ninja 250 which I still have. Anyways, the kz has about 67 000km on it, it has a new paint job, new tires, new fork seals and the carbs have just been done (according to the previous owner). I think I got a good deal on it but im not sure. It has some possible engine trouble and im just wondering what it is/how much it will cost to fix. here is a youtube clip so you can hear what it sounds like.
thank you!
thank you!
- 4TheKZ1000
- Visitor
13 Aug 2012 20:23 #542384
by 4TheKZ1000
Replied by 4TheKZ1000 on topic engine trouble?
:dry:
- MFolks
- Thank you received: 540
13 Aug 2012 20:28 #542385
by MFolks
Replied by MFolks on topic engine trouble?
I'd get a manual cam chain tensioner to start with,new igniton coils & sparkplug wires(high tension leads) and check the valve shim clearances.
Cam Chain Tensioners
kzzone.com/tensioners.html
www.kriegercamchaintensioners.com/
- 67637454
13 Aug 2012 20:34 #542386
by 67637454
Replied by 67637454 on topic engine trouble?
doesnt sound good.. is it worth keeping? i paid 1300 for it and dont really want to but a lot into it. should i just throw it back online and try to get something back from it?
- Buda
13 Aug 2012 20:48 #542396
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic engine trouble?
At least shim the valves.....shouldn't cost you much
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- 67637454
13 Aug 2012 21:09 #542401
by 67637454
should this be work i should get done right away? can i go a little bit without getting it done? ive put 900km on the bike so far and just wondering if im doing too much damage by continuing to drive it
