- Thank you received: 2
Running great, then...
- Sellitto42kz
- Sellitto
Have a few questions,
Have been riding my kz since the new build bout 3 weeks not little hear an there. Plugs Foul d out
Got new plugs. Noticed 1-4 burnt great. 2-3 very dark (rich) plugs.... Noticed every time I came to a stop,out of the over flow tubes two an three were pouring out. I adjusted the carbs so they don't over flow anymore
First question. How do I test the coil?
Sec. Anyone have a 3ohm accelll coil I could buy off them? I have one good,one shitonme
Three. any suggestions.?
Bummin I ride for a day an then I need new plugs
- N0NB
- Blue handles better
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- bountyhunter
- Thank you received: 337
You can't. Coils fail with a high voltage arc down which usually starts happening when they warm up. Bench test won't find that.Sellitto42kz wrote:
Try switching coils to see if the problem follows the coil. If it does, bad coil. If not, carb problem.
Might be a carb problem. If they sat for a while during the rebuild, may have dried out or had gas gunk up inside?Sellitto42kz wrote: Got new plugs. Noticed 1-4 burnt great. 2-3 very dark (rich) plugs.... Noticed every time I came to a stop,out of the over flow tubes two an three were pouring out. I adjusted the carbs so they don't over flow anymore
- Sellitto42kz
- Sellitto
Sorry if not. Frustrated..
I did run the bike. Ran on two cylinders. Will my munkyn around all day tomorrow keep u posted.
- kzz1king
- Thank you received: 52
Wayne
Home built KZ1000 turbo setup
- Sellitto42kz
- Sellitto
I plugged in the good (extra) coil an sparked great.
So hopin it's just the carbs..
Which I really really want some bigg carbs to haul ass with.
Any suggestions? Carb boots?
- MFolks
- Thank you received: 540
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together.
The sparkplug caps should read 5K OHMS(5000), any higher, or a reading of infinity means new caps should be ordered. When re-installing the old or new sparkplug caps, cut about ¼” off the sparkplug wires for a new un-corroded connection.
Ignition Coils And Sparkplug Wire Choices
What came with the bike, were ignition coils that even when new were marginal, add years of cooking under the tank in the stop and go traffic, and the coils will probably fail when hot.
Replacement coils can be bought at www.z1enterprises.com I believe “Emgo” is the brand. They also carry the popular Dyna 2.2 and 3 ohm coils, along with replacement sparkplug wires.
Now, you have a choice on sparkplug wires:
1.Copper plug wires with no supression caps (the best choice, but will produce audio noise Radio’s and TV’s). Not only do the copper core wires deliver better spark, they will also deliver a much longer lifespan - carbon core wires are prone to erratic spark delivery and early breakdown, short lifespan.
2.Copper plug wires with supression caps(a built in 5000 ohm resistor, that can sometimes fail, like what came with the bike).
3.Copper plug wires with no supression caps, but using resistor plugs(the “R” in the plug number, like B8RES).
4.Supression plug wires with no supression caps.
NEVER use resistor plugs and supression caps or supression plug wires, as now there will be two (2) sources of resistance in the secondary windings of the ignition coils, greatly reducing the spark energy.
Another choice is the Accel 3 ohm coils, with a similar, primary(small wire)electrical connection, using ring terminals as the Dyna ignition coils do. Whatever brand of coil you go with, make sure the primary wires will clear the mounting hardware, as the spacers come awfully close, possibly blowing a fuse. Some riders have replaced the metal spacers with non conductive Nylon spacers, reducing the chance of an electrical problem.
7mm sparkplug wires will fit the stock ignition coils(if they have replaceable wires, indicated by screw off caps on the coils with ridges). The sparkplug wires fit into a port with a brass ”Stinger” that goes into the sparkplug wire or lead(the Brit’s. Canadians, and other countries call the sparkplug wires “High Tension Leads”).
- N0NB
Excellent information.
Nate
- bountyhunter
There is a way to Ohm out a coil which will fail to detect about 99.9% of bad coils. It will find one that is shorted out completely or blown wide open. There is a very expensive piece of equipment that generates high voltages that can find some bad coils arcing down, most people don't have access to it. Swapping coils side to side is the best test.Sellitto42kz wrote: R u sure... A friend of mine tested the 3 ohm that was bad. He's out of town I figured I'd check on here..l there has to be a way to test them...
- kawasaki mike
- kawasaki mike
- Thank you received: 4
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
