cam chain
- torquey
12 Aug 2012 19:57 #542157
by torquey
79 kz650 sr pods mac 4-1 dynaS dyna coils
cam chain was created by torquey
Any guesses how many crank teeth chain can jump before valve-piston interference? Also is there an easy way to get chain to jump back a tooth or so without cracking the case?
- bountyhunter
- Thank you received: 337
12 Aug 2012 21:56 #542178
by bountyhunter
Replied by bountyhunter on topic cam chain
I don't know for sure, maybe a couple but I wouldn't try finding out.
You don't have to split the cases to work on the chain and tensioner assembly, just lift the valve cover.
- torquey
12 Aug 2012 22:24 #542181
by torquey
Replied by torquey on topic cam chain
Wasn't really trying to find out, just have a suspition that it did skip a tooth or so. But engine rolls over easily by hand w/ wrench on crank bolt. Just finished dry comp test, got #'s ranging from 60 to 80. Don't know if that's good or not.
- Dragone
13 Aug 2012 06:31 #542235
by Dragone
Replied by Dragone on topic cam chain
Those compression numbers you listed are low. 160-188psig consistent on all cylinders is more in the ball park.
- Thank you received: 2098
13 Aug 2012 07:04 - 13 Aug 2012 07:07 #542237
by Patton
Replied by Patton on topic cam chain
If not already done, would:
Hold throttle wide open during the compression test;
Repeat compression test after placing a spoonful of motor oil inside the combustion chamber through the spark plug hole;
Assure valves clearances are within specs;
Verify the compression test figures by re-testing with a different gauge.
Last edit: 13 Aug 2012 07:07 by Patton.
- torquey
13 Aug 2012 19:04 #542363
by torquey
K. So anyone know how to get the cam chain to skip a tooth or so on the crank without skipping on the cams?
