Oil Leaking
- 750Jack
12 Aug 2012 11:45 #542083
by 750Jack
Oil Leaking was created by 750Jack
hi,
I got a 1980 kz750 ltd about a month ago and I dont really have any knowledge of motorcycles but im trying to learn. just got back from a ride and saw this leak. Is this possibly just some leaky gaskets or possibly (but hopefully not) something more severe. Any help is appreciated.
- pete greek1
- Thank you received: 185
12 Aug 2012 12:29 #542087
by pete greek1
Replied by pete greek1 on topic Oil Leaking
where is it leaking from ? some pitures would be helpful...Pete
- 750Jack
12 Aug 2012 12:54 #542091
by 750Jack
Replied by 750Jack on topic Oil Leaking
sorry, tried to load one last time but i guess it didnt work.
Attachment IMG_0943.jpg not found
- wireman
- Thank you received: 299
12 Aug 2012 13:02 #542093
by wireman
Replied by wireman on topic Oil Leaking
Looks like its leaking from up top and running down,take it to the car wash and scrub it up really good and start looking for leaks
- Paroxyst
- KZ550 -82 B3. KZ550 A1. ZX550A1. CBR600F2
12 Aug 2012 13:44 - 12 Aug 2012 13:50 #542100
by Paroxyst
Replied by Paroxyst on topic Oil Leaking
It comes from the cylinder meets the engine block?
And yes cleaning it and really checking the source with flashlight is the way to go. The tachometer cable where it goes into the cylinder head, that´s a normal oilleakage place.
Last edit: 12 Aug 2012 13:50 by Paroxyst.
- pete greek1
12 Aug 2012 13:46 #542102
by pete greek1
like Wireman says, clean her up, & let er dry, then dust the area liberaly where you think its leaking from, with some baby powder, then start er up & start looking for the leak, you"ll be able to pinpoint it like that, then you can blow, or hose off the powder with no harm done....Pete
- 750Jack
12 Aug 2012 16:28 #542121
by 750Jack
Thanks for the suggestions, ill see what i can find out with the baby powder.
-Jack
-Jack
- MFolks
- Thank you received: 540
12 Aug 2012 16:31 #542122
by MFolks
Replied by MFolks on topic Oil Leaking
The spray on foot powder works good for this too. It's water washable, in case you spray in tight areas.
