- Thank you received: 288
Compatible Alternator?
- les holt
11 Aug 2012 11:32 #541926
by les holt
Compatible Alternator? was created by les holt
My bike has a 74 crank in it with the correct dyno and cover to work with the 78 wiring. I want to step up to the newer style dyno cover which has a different bolt pattern for the alternator. Which rotor do I need to make this happen?
This is the cover I'm wanting to use.
Les
Attachment newdynocover.jpg not found
Les
- wireman
- Thank you received: 299
11 Aug 2012 11:41 #541929
by wireman
Replied by wireman on topic Compatible Alternator?
I know the 79 1000 ltd uses the older left over 78 crankshaft in them with the newer style cover,not the big pin crank like the mkII till 1980.
Maybe check around to see if somebody has a picture of the parts from a 79 to see if they would work.
- Powerstroke_fan
- Thank you received: 83
11 Aug 2012 11:44 #541931
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Compatible Alternator?
I cant quite tell from the picture but i do know if the coil windings are on the outside you gotta stay with that. Because when i was talking with john about my motor, he told me that crank ends are diffrent compared to the one with the coils windings on the inside of the rotor (mk11). John told me he could make them work but you would have to switch a diffrent end on the crank.I guess the holes are diffrent size. Hope that helps.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- wireman
11 Aug 2012 12:07 #541934
by wireman
According to the old babbits site the 78a2 takes stator 21Q76-023 and the 79b3 takes 21076-023.
From what I can see in the pictures it looks physically the same to me anyway,Im guessing if anything the 79 might have a little more output
- les holt
11 Aug 2012 12:14 #541936
by les holt
Replied by les holt on topic Compatible Alternator?
Here's the difference inside.
newer style
older style
Les
newer style
Attachment newdynocoverinside.jpg not found
older style
Attachment olddynocover.jpg not found
Les
- Powerstroke_fan
11 Aug 2012 12:22 #541939
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
The top one is what is on my 80 1000. The bottom pic is what my crank had on it. That is a nice cover wish mine looked that good.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- wireman
11 Aug 2012 12:25 - 11 Aug 2012 12:26 #541940
by wireman
Looks close to me anyway,in 80 the ltd got converted to differant charging system like the mkII
Top picture is the 78,bottem is 79ltd
Attachment 79ltd.gif not found
Attachment 77-78b2.gif not found
Last edit: 11 Aug 2012 12:26 by wireman.
- Powerstroke_fan
11 Aug 2012 12:32 #541944
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Dont know if its true or not but when i ordered my new performance stator from elctrosport which was a big hassle, I ended up with one from a kz 750.They told me thats what charging system i had . I dunno. I had to cut off the oil plug on the wires and install a 1000 plug on but it worked other than that.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- les holt
12 Aug 2012 09:46 #542056
by les holt
I need to change the rotor also so I should have asked what rotor is compatible with my crank that will work with the new cover.
Powerstroke, That cover is a brand new O.E. I found, also got the points cover too. Nice looking parts.
Les
Les
- Powerstroke_fan
12 Aug 2012 10:41 #542069
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ya thats a sweet cover. Man, if you decide you wanna part with it let me know.I hope it works out for you, i just remember what john told me.b/c you know iam building the other motor and i was wanting to just switch all my other stuff over to new motor. Once he seen it wasnt a mk11 crank in it, he told me about it. That was aother reason why i just had him weld up a mk11 crank. i know you need the 80 ltd mk11 style rotor and stator. I can send you pictures of my old stator and dimensions if it will help any.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- les holt
12 Aug 2012 10:55 #542073
by les holt
I remember speaking with John on the same topic when he done my Mk11 crank for the turbo, Just can't remember which year rotor will work on the small pin cranks, I know there is one and I don't want to buy more than the 1 I need.
I'm keeping the cover, I'd like to find a couple more to put back, they're fetching big money now on ebay.
Les
Les
- Powerstroke_fan
12 Aug 2012 11:03 #542075
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Let me know if you want the dimensions on the stator.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
