- Thank you received: 80
Shim conversion - crazy idea???
- OnkelB
When running high lift cams in the 900s/1000s/1100s it's not uncommon to convert to shim on bottom using 650 buckets/tappets, retainers and shims.
But has anyone ever done (or heard of) the opposite, converting a 650 to shim on top using 900/1000/1100 parts?
I can't see why it wouldn't work, what do you think, crazy or...
77 KZ 650 B1, 82 GPz 1100 B2.
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- Powerstroke_fan
dejavoodo41 wrote: The purpose of shim under bucket valve train is to prevent the engine from spitting out a shim at high RPM. Pretty much all of your modern motorcycles use this method of valve adjustment because they all are made for high RPM. There are still a few bikes that use screw and nut adjustment and the only other bike that I'm aware of that uses shim over bucket adjustment is the older BMW K bikes but those are pretty rare these days. I've personally seen what happens when a shim lets loose and it's not pretty. While it's definitely easier to do adjustments on the shim over bucket type it's just not meant for the high rpm's that more modern engines are capable of.
If you include quads, The bombardier ds650 uses the exact same sot buckets with 29mm shims. I adjusted the valves on one and used a couple of my shims from the kz stash.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- OnkelB
I realize the risk of spitting a shim, not something you would want to happen, but a stock 650 has 8 mm lift and shim on bottom, a stock GPz 1100 (KZ1100-B2 in this case) has 9mm lift and shim on top, both bikes redline at 9000 rpms - if shim on top works for the GPz I think it should work for the 650 too.
But like I said, just an idea...
- MDawnz1
- Thank you received: 27
Now that NEVER crossed my mind.
IF it works ,,,,let us know please,,,
1974 Z1a, still 903
- LarryC
Larry C.
- OldSchoolZ
- Thank you received: 33
Remember, don't work on your bike so much you never ride it.
- LarryC
Larry C.
