- Thank you received: 4
HELP IDENTIFYING MOTOR
- jeff12345
- Powerstroke_fan
- Thank you received: 83
10 Aug 2012 20:56 - 10 Aug 2012 20:58 #541835
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic HELP IDENTIFYING MOTOR
looks like its a 77 kz900-A5. You can look it up by the vin number yourself at zedder.com. Go under bike info then scroll down to desired cc range and start reading the engine vin number ranges.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 10 Aug 2012 20:58 by Powerstroke_fan.
- jeff12345
