Engine noise
- Jompa
10 Aug 2012 10:20 #541719
by Jompa
Engine noise was created by Jompa
My 83 GPz 1100 (zx 1100 a1) has a nocking sound coming from the lower part of the engine or
clutch housing.
The sound appears when engines idling with both cold and warm motor.
The noise dissappears when I put in first gear and engage the clutch halfway.
I think it may come from the crank, primary drive or the clutch. Is this a normal Kawanoise or
not ?
Engine and gear works nice,same with the clutch. Valves and timing gear/chain is in good condition.
Any good ideas of what makes the noise ?
clutch housing.
not ?
- Powerstroke_fan
- Thank you received: 83
10 Aug 2012 17:57 #541798
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Engine noise
Mine did the same thing before i put a new clutch in. Maybe your clutch needs adjusted.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- trianglelaguna
- Thank you received: 235
10 Aug 2012 20:49 #541831
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Engine noise
post a video of it
does it do it with the clutch in when slowing down or taking ofF? .... rolling..... or only while standing
post a clip of the sound
1976 KZ900
2003 ZX12R
2007 FZ1000
- gpz1170
- Thank you received: 10
10 Aug 2012 23:24 #541876
by gpz1170
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
Replied by gpz1170 on topic Engine noise
could be a bad clutch basket, J-model are notorious for it. Luckily the basket comes out without splitting the cases. Check the backing springs, when bad they will make some serious noise.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
