- Thank you received: 2
Steering mis-aligned
- Bunty27
1982 KZ550 LTD
- roy-b-boy-b
- Thank you received: 103
- bluej58
- Thank you received: 511
- roy-b-boy-b
bluej58 wrote: Back wheel alinement ?
Ckeck the alignment by sight (looking down the top of the chain) and not by the marks on the swingarm.
Tire pressure. Roy
- Motor Head
- Thank you received: 391
- Old Man Rock
- Thank you received: 225
Unless the front fork tubes are bent, be hard to miss align with everything (wheel spacers, rotor, caliper etc...)correctly in place.
Now you may have some brake caliper dragging that is pulling you left or right.
* Raise the front end off the ground and remove the fender.
Standing directly over the tire spin it and see if rim or brake rotor is warped and coming into
with the brake pads.
* Also, verify tire arrow is correctly installed (forward rotation).
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Bunty27
The bike had a really bad looking front tire (cracked, browned, almost no tread). When I had the bike on center-stand and looked at steering from the front while standing between the tires to ensure that it was aligned with the frame, I then went to the opposite side and while sitting on the seat noticed that the steering was not parallel to me. I thought maybe this was due to the bad tire or the wheel not installed correctly. I replaced the tire (put a new one since it needed on badly) and I noticed that nothing changed on the steering. And when I finally took it out on a test ride, I confirmed that the steering was indeed not parallel to me.
It doesn't look like a real wheel alignment issue. Not sure if this is a fork issue either because I think I notice this even when the front tire is off the ground.
1982 KZ550 LTD
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 1656
- damarble
- Thank you received: 13
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- wireman
- Thank you received: 299
We have a winner!damarble wrote: My triples were twisted in relation to each other and the result is what you are describing. If that's the case, support the bike, loosen the triple clamp bolts, see if you can bring them back parallel to each other.
- Bunty27
1982 KZ550 LTD
