I can NOT find a front sprocket nut! have one?
- whitskz
07 Aug 2012 17:28 #541218
by whitskz
I can NOT find a front sprocket nut! have one? was created by whitskz
My project is missing the front sprocket nut and washer and I can't find one for sale or even info on size to match one to save my life! If anyone has one, or knows which other bikes I could pull one from, please let me know. The motor is a 78 1000.
- 4TheKZ1000
- Visitor
07 Aug 2012 18:13 - 07 Aug 2012 18:23 #541225
by 4TheKZ1000
Replied by 4TheKZ1000 on topic I can NOT find a front sprocket nut! have one?
CALL Z1-ENTERPRISES....Phone: +1 (315) 926-5054 EXT 117 ASK CHRIS TO HELP YOU. YOU WILL HAVE IT IN TWO BUSINESS DAYS.
OR TRY REDLINE: www.redlinecycle.com/Sprocket%20Hdwe.html YOURS WOULD BE THE UPPER LEFT.
Last edit: 07 Aug 2012 18:23 by 4TheKZ1000.
- Thank you received: 2098
07 Aug 2012 18:27 - 07 Aug 2012 18:27 #541228
by Patton
Replied by Patton on topic I can NOT find a front sprocket nut! have one?
Per kawasaki.com both the 20mm nut part number 92016-028 and 20mm lock washer part number 92024-044 are "active" which means available through Kawasaki dealers.
There's a link in my signature for help with navigating kawasaki.com
Last edit: 07 Aug 2012 18:27 by Patton.
