Transmission cover seals - KZ1000J
  • barney
  • barney's Avatar Topic Author
06 Aug 2012 09:38
#540960
Hope you all can help. I want to go to the local bearing and oil seal distributor and get oil seals for my 81 GPZ1100 motor. Without taking my old output shaft cover off and measuring everything,i was hoping somebody out there had the seal numbers or the dimensions(OD. and ID.)
Thanks
Re: Transmission cover seals - KZ1000J
06 Aug 2012 09:54
#540964
Take a look at the parts diagrams on Kawasaki.com. They will show a seal # that a bearing distributor may be able to match. Ed
  • barney
09 Aug 2012 08:35
#541525
I checked the Kawasaki part numbers . They dont show all the (what look like seal) numbers. So i ask the same question.Does anyone have the dimensions for all the seals on the tranny cover?(gasket not necessary). Or even better the actual seal numbers
09 Aug 2012 09:28
#541532
May try the link in my signature for help with navigating kawasaki.com and locating the applicable part numbers of seals, etc.
Good Fortune! :)
09 Aug 2012 09:48
#541534
barney wrote: I checked the Kawasaki part numbers . They dont show all the (what look like seal) numbers. So i ask the same question.Does anyone have the dimensions for all the seals on the tranny cover?(gasket not necessary). Or even better the actual seal numbers
I don't have the dimensions, but which seals in the diagram below are you trying to find?
Attachment 0a1.jpg not found
  • barney
09 Aug 2012 21:05
#541610
92049D is a problem as you can see , the others show what may be good numbers for my local bearing and seal distributor.
09 Aug 2012 21:58
#541617
So if I understand correctly, you need 3 seals for the tranny cover. These are shown in the diagram as part numbers 92049-004; 92049-1017; and 92049-1070. If this is correct you are in luck because all 3 are still available from Kawasaki. Part number 92049-1070 has been superseded by part number 92049-1567. The other 2 are available using the original part numbers. Ronayers.com lists the prices as:
92049-1567 = $7.73
92049-004 = $3.92
92049-1017 = $4.04
Attachment 0000f.jpg not found
Attachment 0000h.jpg not found
Attachment 0000i.jpg not found
  • barney
10 Aug 2012 23:26
#541878
Thanks 650ed i figured they would be alot more pricey from Kawasaki. Appreciate your help.
Cheers Barney
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
15 Aug 2012 01:59
#542708
just an add-on, I just changed these seals but everyone seems to forget a skinny O'ring the goes on the drive shaft between the bearing and the sprocket sleeve. This O'ring is usually the culprit when oil leaks.
  • barney
15 Aug 2012 13:50
#542792
Thanks for the tip
