petcocks? adapter plates?
- purls
02 Aug 2012 16:49 #540290
by purls
1983 KZ750 Spectre
1978 KZ650B2A
petcocks? adapter plates? was created by purls
I'm looking for an aftermarket petcock, and all I can find are pingel. Anyone know where to get anything cheaper? I'd like to get a two piece design so i can use the plate to block off the tank for cleaning.
Thanks a ton.
Thanks a ton.
1983 KZ750 Spectre
1978 KZ650B2A
- Thank you received: 1656
02 Aug 2012 18:56 - 22 Jan 2013 21:09 #540326
by martin_csr
Replied by martin_csr on topic petcocks? adapter plates?
never mind my error
Last edit: 22 Jan 2013 21:09 by martin_csr.
- N0NB
- Blue handles better
02 Aug 2012 23:34 #540388
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic petcocks? adapter plates?
Z1 Enterprises has the plate which is a Pingel and also a cheaper manual petcock, Bikers Choice or some such. I've got three of the sets and they've all worked out fine.
Nate
- Powerstroke_fan
- Thank you received: 83
03 Aug 2012 14:33 #540504
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic petcocks? adapter plates?
My bike already had a pingel on it when i bought it few years ago. I really like it alot. I had to rebuild it last winter and i went to buy rebuild kits and they are expensive but you get enough for three rebuilds. Cant buy single rebuild kits. But easy to rebuild. But ya they aint that cheap for everything.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
