Help! Jetting 26's with pods and header.
  • etbike3135
  • etbike3135's Avatar Topic Author
01 Aug 2012 22:01
#540103
I thought I would try and get a set of VM 26 carbs going and try swapping them out from good running 28’s. The bike has a header and pods. It thought I read on here that the common jetting was 120 mains and 20 pilots, one down on the clip.
Drove the bike about 3 miles and fouled the plugs out! I thought this was the setting everyone was using! There was a dead spot right off idle but only slight, they did run ok but not like my 28’s which I love.
These are 76 carbs with the air screws on the side.
Oh, 1980 LTD 1000.
1973 Kawasaki Z1
18 years in dragbikes
  • baldy110
  • baldy110's Avatar
Re: Help! Jetting 26's with pods and header.
01 Aug 2012 23:17
#540117
First ? that comes to mind is, why would you do that if the 28's were running good. Swapping in a set of 26's is a downgrade.
01 Aug 2012 23:22 - 01 Aug 2012 23:22
#540118
If not already done, would first assure fuel levels are within specs (clear tube test), before addressing jet sizes.
Good Fortune! :)
Last edit: 01 Aug 2012 23:22 by Patton.
  • etbike3135
02 Aug 2012 08:12
#540209
So the jet sizes are the same as what others are using with pods and header?
1973 Kawasaki Z1
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
02 Aug 2012 12:12
#540250
Do you have a baffle in the header? Try removing it. That is the jetting I would run.
  • asevans
  • asevans's Avatar
02 Aug 2012 23:19
#540381
I got 22.5 pilot, needle jet in middle stock pos, 120 mains. on my 76. 26mm carbs, pods, header. baffle out of my header
i had 20 pilots and clip in the 4th pos and had a little hesitation when i first got on the throttle and it was running rich while cruising so i switched. seems to run pretty good now.
1976 kz900 Mostly stock
1978 Z1-R Project
  • etbike3135
03 Aug 2012 07:45
#540430
Thanks asevans. I suppose if I move the clip back to stock then my pilots wont be enough and Ill have to do the 22.5's?
1973 Kawasaki Z1
