help needed!!!!
  • badazzz1
  • badazzz1's Avatar Topic Author
help needed!!!!
01 Aug 2012 16:12
#540027
just bought a 74 kz9...1075 kit bike sat up for 9 months before i bought it, charged the old battery but just get a click sound from the starter relay....
2000 zx12 1375 60 shot nos drag bike
2000 zx12 street bike
1974 z1 1075 (work in progress)
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: help needed!!!!
01 Aug 2012 16:17
#540028
Do you have a multimeter? If you do, check the battery voltage. You may have a bad or weak battery.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: badazzz1
  • Del_Herring
  • Del_Herring's Avatar
Re: help needed!!!!
01 Aug 2012 16:18
#540029
Could try jumping from the battery directly to the starter with a set of cables. If starter turns that way, it's a bad relay, fairly common in my automotive experience. Make sure it's not in gear, and all the other stuff you'd normally do before starting a bike.
If the starter still doesn't turn, probably the starter, unless the engine seized in that short time, which seems unlikely if you had it running fine before. But since you just bought it who knows?
That's the easy/free test to get started with at least.
1983 KZ750-N2 Spectre
Re: help needed!!!!
01 Aug 2012 16:20
#540033
A 1974 is a Z1 (as in $$$$). Have any pictures? Ed
  • badazzz1
Re: help needed!!!!
01 Aug 2012 17:12 - 27 Dec 2020 05:42
#540042
thanks fellas!
Last edit: 27 Dec 2020 05:42 by KZQ.
  • badazzz1
Re: help needed!!!!
01 Aug 2012 17:16 - 26 Dec 2020 18:45
#540044
ed...just the ones i posted on here, i'm in the process of painting it...."black cherry" the color my zx12 was!!! ($$$$) wow did't know that....well that makes me feel alot better for what i picked it up for!!!!
Last edit: 26 Dec 2020 18:45 by KZQ.
  • badazzz1
Re: help needed!!!!
01 Aug 2012 17:38 - 26 Dec 2020 18:45
#540048
ED...look under just scored, there's two pics. didn't know the guy i bought it from was on here also so you may see it a few times :P
  • peter1958
  • peter1958's Avatar
Re: help needed!!!!
01 Aug 2012 18:20
#540058
I hope you never show pictues or ever get it running
  • badazzz1
Re: help needed!!!!
01 Aug 2012 22:57
#540112
peter1958 wrote: I hope you never show pictues or ever get it running
why would you say something like that????
  • peter1958
Re: help needed!!!!
03 Aug 2012 19:29
#540570
Just seen this and it couldnt have been me . might have been craig later
  • badazzz1
Re: help needed!!!!
28 Aug 2012 23:37
#545385
got her running.... man it sounds sweet :laugh:
