Clutch slipping when bike is cold !!
  • Granitestatekz
  • Granitestatekz's Avatar Topic Author
01 Aug 2012 11:16
#539970
I have an 83' KZ1100A shaft 20k on odo. Clutch will slip when bike is first run and only going 3k or higher on the tach, after it's warmed up say 5-6 miles down the road it's fine. I did put a new clutch cable on so I'm thinking it's me and I don't have it adjusted right ? Could I need the major adjustment down at the clutch rod ? Bike did sit for 5-6 years before I started ridint it here the last 2 months and been have fun hammering on it lol.Seems once the oil gets good and hot and some heat into the clutch plates it's fine.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
Re: Clutch slipping when bike is cold !!
01 Aug 2012 11:23
#539973
If you havent done your adjustments yet as the manual states, I would start there. Also make sure your oil is rated for a wet clutch. If not corrected by doing these items I would inspect clutch parts for wear and warpage
  • DoubleDub
  • DoubleDub's Avatar
01 Aug 2012 11:24
#539974
If both of those are done and it still slips, it could be your clutch springs being too weak. They are cheap from Z1E and easy to replace. Just need clutch springs, clutch cover gasket, and probably an oil change or oil top-up.
  • Granitestatekz
01 Aug 2012 12:10
#539978
Ok I will check all or make all the proper adjustments on the clutch and see. I'm using good old Castrol mineral base motorcycle oil 20w50. Oil has only 1k on it.
01 Aug 2012 12:55
#539983
Definitely adjust the clutch according to the Kawasaki Service Manaul. Does the oil bottle say that it is JASO-MA rated? Ed
01 Aug 2012 14:21 - 02 Aug 2012 00:46
#540006
Granitestatekz wrote: ...major adjustment down at the clutch rod ?....
Remove cover plate
Loosen lock nut
set gap on screw
tighten lock nut
Reinstall cover plate
Estimated ET:
sober @ < 60 seconds
knee-crawling, commode-hugging drunk @ < 120 seconds (due to fumbling with tools)
:lol: :laugh: :lol:
Good Fortune! :)
Last edit: 02 Aug 2012 00:46 by Patton.
  • Granitestatekz
02 Aug 2012 00:40
#540142
Well I did all the manual stated adjustments and works pissah now ! Will take for a longer ride( need to gas up) , but it didn't slip at all and clutch feel and ingagement right off the bottom is there. The adjustment reminds me of my Rekluse on my 12' KTM 300. Pretty simple to do.
