Lost slack in cam chain?
- Iheartkz
31 Jul 2012 16:49 #539787
by Iheartkz
1978 kz650 B pods kerker 4>1
1979 kz650 B3 pods kerker 4>1 accel pump
Lost slack in cam chain? was created by Iheartkz
Ok, so I was putting some new shims in my valves today and as soon as I pulled the idle sprocket off I suddenly lost all the slack in the chain. I then took the tensioner out, but still no avail. I rotated the engine to see if I could get the chain to slacken back up, but no avail. My problem is that there is not enough slack in the chain to seat both cams. Why would I not have enough slack in the chain to put the cams back? Any help would be appreciated.
- Powerstroke_fan
- Thank you received: 83
31 Jul 2012 16:56 #539788
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Lost slack in cam chain?
sounds like the timing chain might have came off the crank.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Iheartkz
31 Jul 2012 17:00 #539789
by Iheartkz
Replied by Iheartkz on topic Lost slack in cam chain?
so I probably just need to keep jiggling it to get it back on?
- Powerstroke_fan
01 Aug 2012 13:09 #539991
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
ya
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Powerstroke_fan
01 Aug 2012 13:13 #539992
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
and make sure you get your crank back in time.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- OldSchoolZ
- Thank you received: 33
01 Aug 2012 15:15 #540013
by OldSchoolZ
Remember, don't work on your bike so much you never ride it.
Replied by OldSchoolZ on topic Lost slack in cam chain?
The old Z's almost have to be straight up and down. If you have a leaning side stand, that can be enough to have the chain slip sideways off the crank gear. Once to get chain aligned correctly, insert exhaust cam first keeping chain tight and so on.....
