Some KZ750/4 Questions
- Kevin STP
83 Spectre 750
- Link14
- Thank you received: 6
2. Not sure if mufflers can get restricted, but it's usually the other way around
3. Haven't heard much about jets wearing
4. KZ's are normally cold-blooded. Mine usually took about 4-5 minutes to warm up. Always needed choke to start in the morning.
5. Have to troubleshoot more on the stumbling, but if you still have the smog system on, yank it off! Really helps with the stumbling and popping.
Good Luck!
- Thank you received: 1656
- Thank you received: 2829
+1 As usual, Martin has the correct info. If your KZ750-4 has the stock exhaust system it should have the crossover pipe. Edmartin_csr wrote: The stock exhaust systems on the KZ750-4s have a crossover muffler connector pipe.
- Kevin STP
The emission crap is gone,replaced with a piece of vacum hose.
83 Spectre 750
Attachment 000001_2012-07-31.jpg not found
Attachment 00000_2012-07-31-2.jpg not found
- Kevin STP
83 Spectre 750
- Kevin STP
83 Spectre 750
- Del_Herring
- Thank you received: 29
1983 KZ750-N2 Spectre
- Del_Herring
As far as telling if a muffler is shot, I've never actually looked at what kind of mufflers these are. But they do slide right off the back of the header. I would guess they're a straight through with some sort of packing design, so pull em off and see if you can look through them. If you can, you should be good to go.
- Kevin STP
83 Spectre 750
