What is the best gasket kit to use?
- hoosierkaw83
- Motor Head
- Thank you received: 391
- Thank you received: 2064
- bountyhunter
- Thank you received: 337
- 4TheKZ1000
- Visitor
- hoosierkaw83
- wireman
- Thank you received: 299
Attachment PERMATEX20SPRAY20COPPER20COAT_2012-07-30.jpg not found
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- bountyhunter
Scrape clean with a razor blade edge. Clean with acetone. Don't use grinder or wire brush.hoosierkaw83 wrote: can you tell me about surface prep?
- 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- wireman
Ive had to cut a gasket or 2 in the past to get things done,gotta do what ya have to do! :woohoo:Powerstroke_fan wrote: heck wireman probally cuts his gaskets from cereal boxes and coats it with copper spray gasket material. :woohoo: :woohoo: :laugh: No seriously i use the copper spray gasket maker on everything it works awsome.
