Help with exhaust and some gaskets driving me nuts
- andyn4188
Attachment 0620121945411.jpg not found
- DiamondSkyBlue1000
- Thank you received: 40
- Thank you received: 2098
May then Google the part number to help find a source.
- Thank you received: 2829
- Thank you received: 1656
martin_csr wrote: When you say the exhaust system is wrong, what exactly do you mean?
As for the gaskets: Using the diagrams at Kawasaki.com.
Cross-reference & supersession info for the 1982 KZ750-M1 CSR:
RH engine cover gasket: 14046-033 (Cancelled) -->> 11060-1590 (Active limited quantity)
Transmission cvr gasket: 11060-1056 (Cancelled) -->> 11061-1090 (Active)
Generator cover gasket: (Cancelled) -->> 11060-1421 (Active)
Part #14046-033 - Now #11060-1590, Gasket, RH Engine Cover - Available for $12 at:
www.nwvintagecycleparts.com/search-resul...rch.x=11&search.y=12
Part #11060-1056 - Now #11061-1090, Gasket, Transmission Cover - Available for $4 at:
www.nwvintagecycleparts.com/search-resul...arch.x=5&search.y=10
Part #11060-1421 - Active - Any dealer can order. Available for $13.37 at:
www.ronayers.com/Search/N/687
- andyn4188
and i still don't know what to do about my exhaust they are not big enough to fit into the engine clamps :S
- andyn4188
- bountyhunter
- Thank you received: 337
From people with aftermarket systems that don't use them....andyn4188 wrote: where do you get split colars?
I don't know if I still have mine?
Exhaust system may be stock, and if so the split collar part number is 92027-1241, according to kawasaki.com.
Google 92027-1241 which provides links to several sources where the part is supposedly available.
Could also send a parts request to Z1 Enterprises, who might know of an alternative part, or be able to locate this particular part, or advise of being sol, or whatever.
Perhaps a longer collar with same contour from a different model could be shortened to fit.
Attachment 00000_2012-07-30.jpg not found
Attachment 00000_2012-07-30-2.jpg not found
