- Thank you received: 6
Ok, now my Push Rod Seal is leaking.
- badrhino
28 Jul 2012 03:22 #539185
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Ok, now my Push Rod Seal is leaking. was created by badrhino
Where does a person find a push rod seal for a KZ1000J motor?
I have looked on Bike Bandit and Z1E and didn't see it available.
Franken Z!
- jeffasaki
- Thank you received: 44
28 Jul 2012 03:30 #539186
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic Ok, now my Push Rod Seal is leaking.
measure it and check chicogo rawhide or cr seals in viton
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- roy-b-boy-b
- Thank you received: 103
28 Jul 2012 07:55 #539190
by roy-b-boy-b
Replied by roy-b-boy-b on topic Ok, now my Push Rod Seal is leaking.
Valve stem seals? Call Z1E. Thay have them.
- badrhino
28 Jul 2012 12:16 #539219
by badrhino
Franken Z!
Replied by badrhino on topic Ok, now my Push Rod Seal is leaking.
Roy, Push rod seal.
Also I noticed when going to change the oil and filter that I don't have the filter plate/cover on my bike . Is that something that you absolutely need?
Franken Z!
