Why would one pipe get hotter than the other
- Juggalo82jfl
27 Jul 2012 21:21
I have a 440 ltd and I noticed the right pipe gets a lot hotter by the engine than the left does any one have a possible answere for me plz
- bountyhunter
Re: Why would one pipe get hotter than the other
27 Jul 2012 21:32
Carbs not synchronized
Carbs need cleaning/work
Serious disparity between cylinders on compression/valves etc
Ignition problem
Ignition problem
The following user(s) said Thank You: Juggalo82jfl
- trianglelaguna
28 Jul 2012 00:44
to get to the other side
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- bugsinmyteeth
28 Jul 2012 02:13
Any other symptoms? Is the bike misfiring? Do you need to have the choke on longer than normal or to keep it running? Do the RPMS increase when you are sitting at a stop light and you are idling?
One possibility is that the valves are tight in that cylinder. WHen was the last time you checked the valve clearances?
The probable cause is that the gas mixture is too lean on that cylinder. It could be from dirty carb or air leaks anywhere from the air box to the rubber boot between the carb and head. Take the spark plug out and look at it. What does it look like? If the electrode looks white it is from a lean mixture.
Old School Is Cool!
1975 Kawasaki 900 (Z1B)
1982 Suzuki GS750E
Northern KY
1982 Suzuki GS750E
Northern KY
- Medina
28 Jul 2012 08:00
What do the plugs look like?
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
Medina, Oh
My Bike Thread
