1978 Kz 650 engine compatibility
- justino911
27 Jul 2012 14:19 #539017
by justino911
Justin
Kz 650 1978 restore project
1978 Kz 650 engine compatibility was created by justino911
I need to get a new engine or work with a donor engine for my old Kz.
But i was wondering what engines are compatible with the 1978 650 kz frame.
Justin
- baldy110
- Thank you received: 512
27 Jul 2012 17:03 #539061
by baldy110
Replied by baldy110 on topic 1978 Kz 650 engine compatibility
Any KZ650 and KZ750 (4 cylinder) will bolt right in.
The following user(s) said Thank You: justino911
- murr50
- Thank you received: 3
28 Jul 2012 02:07 #539177
by murr50
77kz650 had a 3 phase regulator and different flywheel than the other later models... Just keep that in mind. I swapped my 77 engine with a 78 and ran into this.
1977 kz650 C
Replied by murr50 on topic 1978 Kz 650 engine compatibility
baldy110 wrote: Any KZ650 and KZ750 (4 cylinder) will bolt right in.
1977 kz650 C
