I think my clutch is slipping on my 81 440 ltd
- Juggalo82jfl
27 Jul 2012 08:53 #538956
by Juggalo82jfl
I think my clutch is slipping on my 81 440 ltd was created by Juggalo82jfl
When I'm accerlating and I pull on the throttle to increase speed it acts like its in nutral so I hath to accerlate slowly does neone have ne suguestions on what it could be thank you in advance for any advice
- Thank you received: 2829
27 Jul 2012 08:55 #538958
by 650ed
Replied by 650ed on topic I think my clutch is slipping on my 81 440 ltd
What motor oil do you use? Have you adjusted the clutch using the instructions in the Kawasaki Service Manual? Ed
The following user(s) said Thank You: Juggalo82jfl
- Thank you received: 1656
27 Jul 2012 09:28 - 22 Jan 2013 20:57 #538962
by martin_csr
Replied by martin_csr on topic I think my clutch is slipping on my 81 440 ltd
Illl
Last edit: 22 Jan 2013 20:57 by martin_csr.
- Juggalo82jfl
27 Jul 2012 11:40 #538981
by Juggalo82jfl
Replied by Juggalo82jfl on topic I think my clutch is slipping on my 81 440 ltd
Ok I just did the clutch adjusting and that didn't work by any chance could the clutch spring plate be lose and that be causing my problem
- Juggalo82jfl
27 Jul 2012 12:03 #538987
by Juggalo82jfl
My bike says to use 10w40 so that's what I use
- Del_Herring
- Thank you received: 29
27 Jul 2012 12:44 #538992
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic I think my clutch is slipping on my 81 440 ltd
See if this finally works, I seem to be having internet issues.
There's more than one kind of 10W40. If you're using synthetic or low-friction, high-efficiency type oils, they will cause your clutch to slip. If you look around the site, there's some very in-depth analysis of oils. Long story, short, use dinosaur oil. I believe the preferred oil in these parts is the rotella t (the non-synthetic), available at wal-mart. Alternately, if you buy your oil from a motorcycle shop, you should be good.
27 Jul 2012 13:13 #539001
by 650ed
There are dozens of different 10w40 motor oils. Are you using motorcycle oil or car oil? If you use car oil that has friction modifiers it can ruin your clutch. Make sure you use oil that has marked JASO-MA marked on the container. That ensures it is the correct oil for wet clutches. It can be dino oil or synthetic as long as it is marked JASO-MA.
When you did the clutch adjustment did you use the instructions in the Kawasaki Service Manual?
If you did, and the clutch is still slipping you will need to drain the oil and open up the clutch cover to see if the plates are worn or ruined by using car oil. Don't even start project unless you have the manual and the tools necessary to do it right. Ed
Juggalo82jfl wrote: My bike says to use 10w40 so that's what I use
- richard_oxon
- Thank you received: 4
27 Jul 2012 13:32 #539009
by richard_oxon
** KZ1000 B3 1979 ** 1015cc wiseco pistons 33 smoothbores ported head 410 cams
** KZ1000 A1 1977** 1075 wiseco pistons 438 megacycle cams ported head rs34 flat slides
Replied by richard_oxon on topic I think my clutch is slipping on my 81 440 ltd
Also check your clutch cable they do wear out ,
