- Thank you received: 1
No compression
- Sambow614
I meticulously rebuilt the top end according to all specs and procedures but now only have compression of 55/75/60/50.
The head work was done by a highly reputable machine shop as well as the bore for the bran new 1075 wiesco 10.25/1 compression piston kit. My question is... Before the pistons are broke in/ completely seated/ is it typical to have low compression? The compression test was done with carbs off. (shouldn't matter right?) Any info on what this could be would be great. Any common mistakes I could have made? Thanks
77 kz1000 / zx10
- Motor Head
- Thank you received: 391
- Sambow614
- Motor Head
www.kzrider.com/forum/2-engine/445033-79-kz1000-cam-timing-help
- bountyhunter
- Thank you received: 337
- LarryC
Sambow614 wrote: So I've been building this bike for about 5 months now and ran into a problem that just stumped me.
Start with valve lash check and make sure the cams are timed correctly.
Larry C.
- bountyhunter
- Ktm181
- Man made it, so Man can fix it
Kt
- Sambow614
I am going to check the valves again via leak test and see what the heck is going on. Thanks again
77 kz1000 / zx10
- Thank you received: 2098
The intake valve must open to suck in air which is thereafter compressed during the compression stroke while both valves are closed.
If the intake valve doesn't open, there's no air intake to be compressed.
