no power
- battlecat
25 Jul 2012 23:44 #538693
by battlecat
'79 Kz650b3 RAT. Used to ride an immaculate cb750. it was boring.
no power was created by battlecat
i'm having trouble getting my bike to rev past 4000 when it's on the road. it will rev up in neutral but has no balls on the when it's in gear. any ideas....?
- MFolks
- Thank you received: 540
26 Jul 2012 00:19 #538703
by MFolks
Replied by MFolks on topic no power
Compression been checked? A new/rebuilt engine may have 180-200 PSI, put a few years on it, and now it's maybe 160 or so. An engine will run at 100 PSI, but produce low power. You should not have more than 10% difference between cylinders.
When you check the compression, do it with the engine cold, and the throttle wide open.
- Thank you received: 2098
26 Jul 2012 00:25 #538707
by Patton
Ignition timing advancer might be stuck in idle position.
It's not supposed to look like this:
Might need lube, or clean and lube.
Replied by Patton on topic no power
battlecat wrote: i'm having trouble getting my bike to rev past 4000 when it's on the road. it will rev up in neutral but has no balls on the when it's in gear. any ideas....?
The following user(s) said Thank You: battlecat
- loudhvx
- Thank you received: 1616
26 Jul 2012 00:26 #538708
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic no power
May want to make sure the advancer is moving freely.
1981 KZ550 D1 gpz.
Other links.
