Baffles or no baffles?
- Calico
24 Jul 2012 15:39 #538252
by Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
Baffles or no baffles? was created by Calico
Baffles or no baffles? That is the question. But . . . it's baffling. See I always thought that removing baffles wasn't just a sound thing but that it (even in a small measurement) helped. But I just read in someone's discussion that removing baffles is bad for your low to mid. Any opinions?
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- wireman
- Thank you received: 299
24 Jul 2012 15:42 #538255
by wireman
Replied by wireman on topic Baffles or no baffles?
Yes it kills off low end torque depending on your combination this can be good or bad
The following user(s) said Thank You: Calico
- Thank you received: 2829
24 Jul 2012 15:53 #538261
by 650ed
Replied by 650ed on topic Baffles or no baffles?
Assuming your bike is otherwise stock or tuned for baffles, removing them is not going to add power.
- Calico
24 Jul 2012 17:11 #538285
by Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
Replied by Calico on topic Baffles or no baffles?
Right. I know most people do it for sound but I was concerned about losing power due to a lack of back pressure. Thanx guys! Oh, one other thing. I just rebuilt the starter clutch and installed it. But as I'm installing the clutch I noticed that the the spring bolts require 90" lbs. How important is that? The only reason that I ask is that I'm doing this on a budget and my only "lbs torque wrench starts at 130.
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- wireman
24 Jul 2012 17:14 #538288
by wireman
Thats right between 7-8' lbs by my math,id say put some blue lock tite on them and snug them as tight as you can with a 3/8 drive ratchet while holding it.
- Calico
24 Jul 2012 17:27 #538290
by Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
I think I understand. Do you mean by hand with the socket only?
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
24 Jul 2012 17:32 #538293
by 650ed
If you plan to do much of your own work on the bike you may as well plan on getting a more sensitive (smaller scale) torque wrench. Otherwise stripped fasteners and timesert repairs are in your future. I find that my 30-250" lb works very well for all the lighter torque settings. Ed
- wireman
24 Jul 2012 17:33 #538294
by wireman
No with just the 3/8 drive ratchet and socket,no air tools or breaker bars required to reach that amount of torque.
- Calico
24 Jul 2012 17:43 #538300
by Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
Thanks guys!
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
