Starter Clutch Gear housing broken, any pointers t
- kz1100warrior
23 Jul 2012 06:03
Hi, got a 81 1000J , the problem i have is that the housing that the starter gear sits in is broken off at the bottom, where the pin goes in. I have tried steel putty but not holding. If i weld that pin on so it doesnt rotate, what will be the outcome of that. Or does anybody have any other soluton to fix this housing.Thanks.
- les holt
Re: Starter Clutch Gear housing broken, any pointers t
23 Jul 2012 07:59
If I get what your saying you can't weld it, steel pin, aluminum case. I repaired one that was cracked, pulled it together, welded the crack and machined the outside to take a steel sleeve to support it. You'll need the broken pc. or have something made to fit. Sorry, not an easy fix from what I've seen.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- kz1100warrior
23 Jul 2012 08:52
can i weld steel putty to the aliumin casing...
- Nebr_Rex
23 Jul 2012 08:57
You can't weld.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- les holt
23 Jul 2012 09:12
Nope, needs to be aluminum.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
