Sounds of my 79 Kz750 Twin
- cnyl
11 Jun 2006 18:17
We've been messin with tuning my carbs found that my boots were cracked allowing a vac leak. We went up on the main jets. I'm popping when reving it off idle
This is where i'm at. Take a listen tell me what you think.
Reving
media.putfile.com/Kz750-Rev
Idle
media.putfile.com/Kz750-Idle
Post edited by: cnyl, at: 2006/06/11 21:18
Post edited by: cnyl, at: 2006/06/11 21:19
Reving
Idle
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- OKC_Kent
Re: Sounds of my 79 Kz750 Twin
11 Jun 2006 18:19
The links need work, I can't get anything.
Works now!!
Post edited by: OKC_Kent, at: 2006/06/11 21:20
Works now!!
Cashion, OK
78 KZ650 B2 85,000+ miles
- steell
11 Jun 2006 19:34
The bike is only running on one cylinder at both idle and revving
I know the sound well, I actually rode my 80 750 twin on one cylinder when I first got it running, just wanted to see if it would do it
Which side exhaust pipe is not getting hot?
Post edited by: steell, at: 2006/06/11 22:34
- pumps
11 Jun 2006 20:37
I think it is so cool I'm listening to your bike off the web! Ok so Im a geek!
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- cnyl
12 Jun 2006 07:47
steell wrote:
Hmmmmm. When I adjust both pilot screws they both make a difference. Let me check again.
Which side exhaust pipe is not getting hot?<br><br>Post edited by: steell, at: 2006/06/11 22:34
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
- Biquetoast
- King Jeremy The Wicked
12 Jun 2006 08:03
cnyl wrote:
Hmmmmm. When I adjust both pilot screws they both make a difference. Let me check again.[/quote]
Is it possible that the recording mic was right next to one of the exhausts (if it's two-into-two), so it only picked up the one?
..I don't know, I can't listen to it on Linux, it's apparently a Windows-formatted file...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- cnyl
12 Jun 2006 08:12
It's got a 2 into 1 on it. I just checked the headers and they are both hot but the right side is hotter. The mic was about 2 feet away from the pipe.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
- Biquetoast
12 Jun 2006 08:14
cnyl wrote:
What RPM do you idle at?
kz750twins.com
kz750twins.com
- got12narow
12 Jun 2006 08:15
Don't claim to know much (just learning,) but my 77 seems to give the same popping. Only upon initial/cold starting. I've dug through the archives a bit, and found that if your boot from the air box to the carbs is leaking, then your running too rich? I think. I checked mine, and it is in fact torn. I haven't yet replaced them, but mine evens out and stops backfiring once it warms up.
- cnyl
12 Jun 2006 08:28
According to the tach i'm running at 1000 or a hair over. For some reason the idle screw won't lower the rpm
anymore than it is.
anymore than it is.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
- steell
12 Jun 2006 09:03
Remove the spark plugs and post what they look like (#1 and #2).
A history of the bike and what you have done so far would help a lot
- cnyl
12 Jun 2006 12:35
Hey steell,I pulled the plugs, the #2 looked normal but #1 was carbon fouled. So I cleaned it and put in the #2 cyl.(swapped).
It's running on both.:woohoo:
That seemed to be my problem. Runs great now I almost am afraid to do a sync.. Might mess it up.:laugh: I'll post another sound clip.
Oh..... The spouts that stick out of the intake boots, Do they need to be joined with a hose or plugged off separately?
Thanks all.:woohoo:
Post edited by: cnyl, at: 2006/06/12 15:39
Thanks all.:woohoo:
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
