oil cooler install
21 Jul 2012 23:21 #537557 by zig
oil cooler install was created by zig
i have a 1980 kz750ltd h1 i want to add an oil cooler on it what would i have to do to add it and where would i mount it its air cooled engine
21 Jul 2012 23:39 #537561 by MFolks
  • Paroxyst
  • KZ550 -82 B3. KZ550 A1. ZX550A1. CBR600F2
22 Jul 2012 13:51 #537676 by Paroxyst
Replied by Paroxyst on topic oil cooler install
I got a tip that 10w40 is not necessary unless you drive in wintertime. He said that if oilpressure warning light is coming on when really hot and on idle the I need to change oil to SAE30. Thicker oil with no viscosity is better because it keeps the engine a little cooler and keeps oil pressure where it should. I have not yet tried it but next oil change this autumn I will. What do you other guys think?
22 Jul 2012 14:10 - 22 Jul 2012 14:10 #537677 by 650ed
Replied by 650ed on topic oil cooler install
Paroxyst wrote: I got a tip that 10w40 is not necessary unless you drive in wintertime. He said that if oilpressure warning light is coming on when really hot and on idle the I need to change oil to SAE30. Thicker oil with no viscosity is better because it keeps the engine a little cooler and keeps oil pressure where it should. I have not yet tried it but next oil change this autumn I will. What do you other guys think?
You should to do more research before making this change; it is a really bad idea to use straight 30w oil. No offense intended, but it is clear by your statement "thicker oil with no viscosity is better..." that you do not fully understand motor oil properties. Ed
Last edit: 22 Jul 2012 14:10 by 650ed.
  • Paroxyst
22 Jul 2012 14:30 - 22 Jul 2012 14:31 #537679 by Paroxyst
No offense taken :) Interesting. This was the local shop and he said that 20w50 is the best and we use it in all our bikes and you should too but if you only drive in the summertime and want the oil pressure back you can just aswell use straight 30. His words and I really would want to know more. I just automatically trusted him since he has his own mc shop since early 80´s so I thought he knew what he was talking about. I was thinking switching from 10w40 to 10w30, is that "thicker" oil?And is it better for oil pressure?
And I promise I will not advise anyone on the subject oil in the foreseeable future ;)
Last edit: 22 Jul 2012 14:31 by Paroxyst. Reason: Added some more
22 Jul 2012 17:12 #537690 by pete greek1
Replied by pete greek1 on topic oil cooler install
the lower the number, the thinner the oil,...so 10-30 would be thinner than 10-40..Pete
  • Paroxyst
22 Jul 2012 17:31 #537691 by Paroxyst
Mhmmm so 20-50 WOULD be better for oilpressure?
22 Jul 2012 17:47 - 22 Jul 2012 17:47 #537694 by undiablo
Replied by undiablo on topic oil cooler install
Yes, 20W50 should be better for higher oil pressure, but it is the thickest oil you should use in a KZ. May be if your piston ring seals are not 100% good, it is OK to use it.
If you have below 0 Celcius degrees in winter, I recommend you stick with 10W40 oil, it will help with cold starts. ;)
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 22 Jul 2012 17:47 by undiablo.
The following user(s) said Thank You: Paroxyst
  • Paroxyst
22 Jul 2012 18:00 #537696 by Paroxyst
Okay. Sorry zig for hogging your thread like this. So why isnt straight 30 oil any good then? I do not ride during winter so no cold starts.
22 Jul 2012 18:52 #537702 by bountyhunter
Replied by bountyhunter on topic oil cooler install
Paroxyst wrote: Okay. Sorry zig for hogging your thread like this. So why isnt straight 30 oil any good then? I do not ride during winter so no cold starts.
You are still starting "cold" relative to normal operating temp of the oil. It is much thicker at 60F than it is at 230F or whatever temp it normally runs at. Do not run "straight" 30W in any car or bike, it will ruin it. I have also heard some older people claim straight 30 is OK to run in "warm weather", but any good multi grade is better. It's the reason multi grade oils were developed.
22 Jul 2012 21:50 #537728 by 650ed
Right. 10W40 will flow better than straight 30w when the engine is cold so you won't suffer abnormal wear when first starting the bike and waiting for it to warm up. Just as important (probably more important) 10W40 oil will have a higher viscosity (think "thicker") in a hot engine than straight 30w oil.
Paroxyst; below is a link that you should take your time to read and understand. Then you can explain to your mechanic friend why he doesn't know what he is talking about. Pay special attention to the text in the area that discusses:
"I can't tell you how many times I have heard someone, usually an auto mechanic, say that they wouldn't use a 5W-30 motor oil because it is, "Too thin." Then they may use a 10W-30 or SAE 30 motor oil. At engine operating temperatures these oils are the same. The only time the 5W-30 oil is "thin" is at cold start up conditions where you need it to be "thin." Therefore, of course, at operating temperatures straight 30w is "thinner" than 10W40.
Here's the link:
www.upmpg.com/tech_articles/motoroil_viscosity/
The following user(s) said Thank You: wireman, Paroxyst
22 Jul 2012 22:30 #537742 by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic oil cooler install
This is what I have, they are pretty hard to find now. You get the idea.
