NEED SOME HELP FOR MY 77' 650
- gweber
21 Jul 2012 14:59 #537471
by gweber
NEED SOME HELP FOR MY 77' 650 was created by gweber
OK SO I BOUGHT MY 77 650 ABOUT A MONTH AGO. SHE RAN FINE UNTIL ABOUT 2 WEEKS AGO. I HAD TAKEN IT TO WORK AND AS I WAS RIDING EVERY TIME I CAME TO A STOP SIGN AND WOULD TURN MY TURN SIGNAL ON IT WOULD DIE ON ME.SO I DECIDED TO JUST GET A NEW BATTERY TO SEE IF THAT WOULD HELP. WELL AS MY BUDDY WAS PUTTING THE BATTERY IN HE CONNECTED THE TERMINALS BACKWARD AND THE BATTERY BEGAN TO BURN SOME OF THE WIRES. WELL ONE OF THE WIRES THAT WAS BURNT UP IS THE ONE FOR THE VOLTAGE REGULATOR. ONCE WE HAD TRIED TO OUT THE CONNECTORS ON RIGHT AS WE PUT THEM ON THE BATTERY IT WOULD REVERSE ARCH EVERY TIME WE TOUCHED THE TERMINALS. SO WE SEARCHED FOR GROUNDED WIRES AND DIDNT FIND ANY. SOMEHOW WE FIGURED OUT THAT IF WE DIDNT PLUG IN THE WHITE AND RED OR WHITE AND PINK WIRE COMING FROM THE VOLTAGE REGULATOR IT WOULDNT REVERSE ARCH. SO NOW I NEED TO KNOW SHOULD I REPLACE THE VOLTAGE REGULATOR OR WHAT SHOULD I DO. ANY INFORMATION OR TIPS WILL HELP!
- Motor Head
- Thank you received: 391
21 Jul 2012 16:55 #537491
by Motor Head
Replied by Motor Head on topic NEED SOME HELP FOR MY 77' 650
If everything is OK with the Rectifier un-plugged, but shorts/ sparks bad, when attempting to plug it in. It is Toast. It has Diodes in it, think one way street for electricity, when blown current can flow in the Wrong direction. =BAD
- gweber
22 Jul 2012 23:23 #537760
by gweber
Replied by gweber on topic NEED SOME HELP FOR MY 77' 650
ok thanks for the words i guess i'll try replacing it and see if that helps at all!
- Mark Wing
- Thank you received: 22
23 Jul 2012 12:48 #537879
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic NEED SOME HELP FOR MY 77' 650
Also make sure your battery is charged up also after you change your rectifier.
Yorba Linda Cal.
- gweber
24 Jul 2012 22:56 #538371
by gweber
ok thanks...do you know of any good places to get the regulator from??
