Cracked generator cover, is it repairable?
  • Bigberst89
  • Bigberst89's Avatar Topic Author
19 Jul 2012 16:49 - 19 Jul 2012 16:53
#537099
I had a little accident and cracked my generator case, it doesnt look that bad, is there anyway I can fix it? Or and other kz models that I can look for to replace it with?
1982 Kawasaki Spectre 1100-D1
Last edit: 19 Jul 2012 16:53 by Bigberst89.
  • MFolks
  • MFolks's Avatar
Re: Cracked generator cover, is it repairable?
19 Jul 2012 18:09
#537106
I'd call around to the welding shops, some do really good work.
Maybe next time get some "Case Savers" www.fastfromthepast.com used to carry them, and I believe www.redlinecycle.com or www.americanclassix.com do.
  • martin_csr
  • martin_csr's Avatar
19 Jul 2012 18:27 - 22 Jan 2013 21:01
#537111
listing ended
Last edit: 22 Jan 2013 21:01 by martin_csr.
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
19 Jul 2012 20:01
#537129
Duct tape, it's the handyman's helper. :laugh:
  • boyracer
  • boyracer's Avatar
21 Jul 2012 10:20
#537441
I wore through the bottom of mine getting frisky in the local hills roads. Had it welded/linished/polished...you couldn't even see where if i didn't tell.
  • Bigberst89
02 Aug 2012 11:46
#540244
Thanks guys for the replies, Not sure if this is a dumb questyion or not but, Is oil suppossed to run through inside of the cover? Some people have been telling me I might have done more damage then just the cover. Is this true?
02 Aug 2012 16:06
#540285
Bigberst89 wrote: Thanks guys for the replies, Not sure if this is a dumb questyion or not but, Is oil suppossed to run through inside of the cover? Some people have been telling me I might have done more damage then just the cover. Is this true?
Above is from FSM for Z1 - KZ900 - KZ1000
There's some oil inside the cover.
Instructions as to removing the cover suggest placing a catch pan underneath to catch the oil.
Am guessing KZ1100 follows suit, but here's a link to the KZ1100 manual:
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
Good Fortune! :)
