KZ750 exhaust gasket?
- Cdiver
18 Jul 2012 23:26 #536920
by Cdiver
1978 KZ750 Cafe Racer
KZ750 exhaust gasket? was created by Cdiver
I have a 750B twin. One of my exhaust ports on one of the heads is leaking a little bit. Is there somekind of dougnut gasket that I can replace or is my pipe messed up. Anyone wanna get rid of a 2 into 1 set up?
- steell
19 Jul 2012 00:48 #536961
by steell
Replied by steell on topic KZ750 exhaust gasket?
There is supposed to be a copper O-ring in each port for the pipe to seal against.
$1-$2 at Z1 Enterprises.
- Cdiver
19 Jul 2012 01:41 #536982
by Cdiver
Great! This will help me put off having to spend $350 for a new pipe for a little while longer.
Replied by Cdiver on topic KZ750 exhaust gasket?
steell wrote: There is supposed to be a copper O-ring in each port for the pipe to seal against.
- KZCool
- Thank you received: 1
19 Jul 2012 02:05 #536986
by KZCool
1976 KZ750 hardtail
Replied by KZCool on topic KZ750 exhaust gasket?
I had to also add a peice of wire hanger to the spacer of mine to add needed space to properly seal it. SOOOO much beter now. just bent it into a circle around the pipe to add about an 8th inch gap.
1976 KZ750 hardtail
- Thank you received: 1656
19 Jul 2012 09:56 - 21 Feb 2013 20:37 #537029
by martin_csr
Last edit: 21 Feb 2013 20:37 by martin_csr.
- bountyhunter
- Thank you received: 337
19 Jul 2012 16:00 #537090
by bountyhunter
Replied by bountyhunter on topic KZ750 exhaust gasket?
I have to use two copper donuts on one side of my 750 twin. Aloways been that way regardless of type of pipe. Don't know why, just is that way. I superglue two donuts together then install on that port.
