- Thank you received: 1
1st oil change
- oldcatawba
17 Jul 2012 23:52 #536684
by oldcatawba
Whadda ya got in that thing son?
1st oil change was created by oldcatawba
I'm changing the oil on my 1982 1000 LTD for the first time.It has a Vance & Hones 4 into 1 header.Does it have to come off to change the filter? Thanks
- peavylotus
- Movin on up
- Thank you received: 15
18 Jul 2012 00:05 #536685
by peavylotus
1980 KZ 1045 LTD Currently Workin' It Out
Replied by peavylotus on topic 1st oil change
I believe it does have to come off, on mine it does. Not for certain though.
- MFolks
- Thank you received: 540
18 Jul 2012 00:37 #536688
by MFolks
Replied by MFolks on topic 1st oil change
How close to the oil filter housing(the round cover under the engine, about 5" in diameter?).
- Motor Head
- Thank you received: 391
18 Jul 2012 01:25 - 18 Jul 2012 10:30 #536693
by Motor Head
Replied by Motor Head on topic 1st oil change
I have the same bike with a V&H on it. The oil filter will come out with the pipe in place. you have to have the bolt out of the threaded section of the motor, and pull the bolt down with the Plate and filter, at a angle. But it comes out. It is much easier with a center stand, if you don't have one hit up KZ1006/ Brian, he would more than likely have one. Here is a picture of how it goes together, also grab a copy of the service manual in my signature.
Also you should take out the Oil Drain Plug, which will allow the rest of the oil to drain out. It the other 17mm headed nut under there on the sump.
Last edit: 18 Jul 2012 10:30 by Motor Head.
- oldcatawba
18 Jul 2012 06:46 #536711
by oldcatawba
Replied by oldcatawba on topic 1st oil change
Thanks for all the replies I wasn't sure if the bollt could come out of the filter or if it had to be removed together.
- oldcatawba
18 Jul 2012 21:26 #536885
by oldcatawba
Are you replacing the exhaust gaskets every oil change?
- Motor Head
18 Jul 2012 23:42 #536932
by Motor Head
Definitely Not me, I don't remove any other parts, just the drain plug, and the filter bolt/ filter assy. You get used to how it comes out, and it Will clear the pipe.
oldcatawba wrote: Are you replacing the exhaust gaskets every oil change?
- oldcatawba
19 Jul 2012 20:46 #537142
by oldcatawba
No Sir I was referring to the gentleman who said he was removing the pipe for oil changing,just assuming if you didn't change out the header gaskets each time you'd have a leak. I did get the filter out without dropping the pipe, thanks for the info!!
- Motor Head
19 Jul 2012 21:37 #537152
by Motor Head
- peavylotus
- Movin on up
20 Jul 2012 04:50 - 20 Jul 2012 05:26 #537234
by peavylotus
Im just a doofus
Last edit: 20 Jul 2012 05:26 by peavylotus.
