kz1100 cam shaft loose!!!!
  • fergieuk
  • fergieuk's Avatar Topic Author
17 Jul 2012 19:48
#536627
My engine has been a bit rattly and started loosing power so figured the valve clearances needed looked at. Took the cam cover off to discover one end of the cam shaft not secured :silly: I've never touched it but the 4 bolts securing cam shaft at one end all stripped so the cam shaft been moving around!
so should i just re-tap the holes and check valve clearances? or should i suspect something more sinister and dig deeper into the engine?
Cheers
Fergie
KZ1100D1
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: kz1100 cam shaft loose!!!!
17 Jul 2012 19:56 - 17 Jul 2012 20:13
#536628
cam cap bolt or bolts stripped out or loose would be my guess.
YOU NEED TIME-SERTS
www.belmetric.com
Last edit: 17 Jul 2012 20:13 by 4TheKZ1000.
  • MFolks
  • MFolks's Avatar
17 Jul 2012 20:13
#536632
What torque are you using for the cam cap bolts? 66 INCH pounds or 8 FT pounds should be the max, otherwise, goodbye 6mm threads. Many Kawasaki manuals are incorrect for this torque in the Kz 1000/Kz 1100 engines.
17 Jul 2012 23:09
#536673
Time to get timeserts and an inch/pound torque wrench. Ed
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
18 Jul 2012 05:11
#536705
MFolks wrote: What torque are you using for the cam cap bolts? 66 INCH pounds or 8 FT pounds should be the max, otherwise, goodbye 6mm threads. Many Kawasaki manuals are incorrect for this torque in the Kz 1000/Kz 1100 engines.
+1!!!!!!!!! Timeserts work well (I have used them on my GPz1100 exhaust cam caps [which were all stripped by the previous owner]).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • faffi
  • faffi's Avatar
18 Jul 2012 05:48
#536706
The proper way is to use inserts, but if there is enough material left, you can also re-thread to 1/4in and save the inserts. But if you do, you must be very careful not to mix up the bolts if you ever remove the cams later.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • fergieuk
18 Jul 2012 05:57
#536707
faffi wrote: The proper way is to use inserts, but if there is enough material left, you can also re-thread to 1/4in and save the inserts. But if you do, you must be very careful not to mix up the bolts if you ever remove the cams later.
I hope to never have to remove cams again!! See the thing is I'm Scottish and you guys talk about these inch things. I was thinking it should tap out a size. My life used to be easy for stuff like that when dad worked in the machine shop, he would custom make me individual bolts or inserts.
anyway will run a tap in and see how i get on, cheers.
KZ1100D1
  • faffi
  • faffi's Avatar
18 Jul 2012 06:22
#536708
1/4 in = 6.3 mm or so. Usually, especially if you use very fine threads, that will work just fine. The next size is 7 mm, which is quite rare when it comes to finding bolts. Plus you will need to reem the holes in the caps and maybe even the dowel pins. So I personally would try 1/4 in as they would likely work very well with minimal work and cost and do the inserts if that fails.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
  • fergieuk
18 Jul 2012 06:25 - 18 Jul 2012 06:27
#536710
Can anyone tell me cam cap bolt size in mm? Cant find my vernier to measure them.
Once I know for sure will ask on local forum for thread repair kit.
KZ1100D1
Last edit: 18 Jul 2012 06:27 by fergieuk.
  • 4TheKZ1000
18 Jul 2012 07:24 - 18 Jul 2012 07:24
#536716
Should be 6-mm bolt size.
Thread Pitch should be 1.0
you really need to purchase a manual for you bike. My manual has all these answers in it. They also have several different conversion charts for mm to inch, foot pounds to inch pounds and so on. If you want to play bike mechanic, GET ONE TODAY.
good luck
Last edit: 18 Jul 2012 07:24 by 4TheKZ1000.
  • fergieuk
18 Jul 2012 07:50
#536717
I do have the manual in PDF format, unfortunately I am dyslexic so find it easier to pick brains of fellow owners on forum. Saves me making brain hurt or asking wife for help. spell check on iPhone has been a revelation to me as well as dictation.
Cheers for all the replies.
Fergie
KZ1100D1
  • TexasKZ
  • TexasKZ's Avatar
18 Jul 2012 12:46
#536773
Hey guys,
Should Fergie be worried about excess wear in the other journals? He did say the cam was moving around....
