- Thank you received: 52
Tear drop cover mod how to
- kzz1king
13 Jul 2012 15:07 #535681
by kzz1king
Home built KZ1000 turbo setup
Tear drop cover mod how to was created by kzz1king
I sold a tear drop cover from a Z/KZ that I had done a cut out on. A few people showed interest so I thought I would pass on how it was done. I am a woodworker so I use a woodworking tools when I can.
1) Polish it up first. Will polish again when done but I think it is good to start with polished.
2) Pick out your design and print it out. Make sure that you are mot going to accidently drop out anything you don't want (ex. center of an A when you cut outside of A out)
3) Design can be cut out to see how you like on a piece of wood or paper mock up of cover.
4) Spray glue the design to the cover.
5) I use a scroll saw with metal cutting blades. I have used woodworking blades also. Use medium speed and hold material down firmly. Pilot holes have to be made to slip the blade. I also cover the piece with the clear,wide cellophane tape, it helps lubricate the blade.
5) A painted piece of tin can be placed behind the cutout, maybe even a light?
Hope this helps.
Wayne
Attachment DSCN1211_2012-07-13.JPG not found
Hope this helps.
Wayne
The following user(s) said Thank You: wireman, Humenik
- jenkrider
- Thank you received: 3
20 Jul 2012 00:18 #537198
by jenkrider
76' KZ900
00' KLR650
82' XV920 Virago
74' Ironhead Sportster
Replied by jenkrider on topic Tear drop cover mod how to
Cool!
76' KZ900
00' KLR650
82' XV920 Virago
- Thank you received: 797
20 Jul 2012 12:42 - 20 Jul 2012 12:46 #537272
by 531blackbanshee
Replied by 531blackbanshee on topic Tear drop cover mod how to
really cool work.
in the same vein,
here is the rest of the cover nicely cut out.
here is the lightend cover from the fatclub z1 racer.
in the same vein,
Last edit: 20 Jul 2012 12:46 by 531blackbanshee.
- kzz1king
20 Jul 2012 21:22 #537379
by kzz1king
Replied by kzz1king on topic Tear drop cover mod how to
531blackbanshee wrote: really cool work.
in the same vein,
I really like the one with the holes. Would look great with the teardrop cut out in some manner.
Wayne
23 Jul 2012 11:06 #537850
by 531blackbanshee
yes it would.
