big score carbs on ebay
- nitrochristian
13 Jul 2012 00:54 #535569
by nitrochristian
need help plz i have been looking for carbs for a while and finally found, need help identifying, im sure they are vm 26s. but need a little more if anyone can help. i scoured these for 39 bucks and they are very nice gotta clean but a good deal i think. i need info so i can order proper gaskets. mains are 110, pilots are 15. id on engine side is 26.6mm. hopefully i can get a year range and i think these were used on kz900s
78 KZ650
96 Ford Bronco
big score carbs on ebay was created by nitrochristian
Attachment carbs1.jpg not found
Attachment carbs2.jpg not found
Attachment carbs3.jpg not found
Attachment carbs4.jpg not found
Attachment carbs5.jpg not found
Attachment carbs6.jpg not found
78 KZ650
96 Ford Bronco
- Tomolu5
- Thank you received: 45
13 Jul 2012 01:12 - 13 Jul 2012 01:13 #535574
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic big score carbs on ebay
They look like the 26mm's that came on my '76 900, I would have to double check to be sure though
Mine:
Last edit: 13 Jul 2012 01:13 by Tomolu5.
- Tomolu5
13 Jul 2012 01:16 #535576
by Tomolu5
Mine:
Also, I'm not at all sure, but the slides look flat on the bottom, which I think indicates early models. Please correct me if in wrong
Mine:
- gd4now
- Denco where did you go?
- Thank you received: 440
13 Jul 2012 01:26 #535581
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic big score carbs on ebay
There should be ID numbers stamped on the flange just below the choke/enricher handle.(see attached pic for location) If you post what the ID numbers are I maybe able to tell you what you have.
The numbers should be in 2 rows like this
101
7 (some other number or letter)
101
1977 KZ650 B1
- nitrochristian
13 Jul 2012 01:36 #535585
by nitrochristian
78 KZ650
96 Ford Bronco
Replied by nitrochristian on topic big score carbs on ebay
the numbers are (102 and 5A) below that
78 KZ650
96 Ford Bronco
- gd4now
13 Jul 2012 12:21 #535651
by gd4now
1977 KZ650 B1
OK I am pretty sure the ID of 1025A would make them vm26ss carbs, and they began life on a 1978 1000 A2.
IIRC stock they came with a 15 pilot, a 105 main, an O5 needle jet, a 5DL31 jet needle set on the 3 slot and a 1.5 cutaway on the throttle slide.
1977 KZ650 B1
