- Thank you received: 1
bike is running hot
- zig
- Motor Head
- Thank you received: 391
- zig
- Motor Head
You need to pull the small 6" or so sized cover from the right hand side of the engine. That is where it all happens. You should be able to see the marks, on the outside edge of the advancer, and the permanent mark on the case, which is straight up. These will have a T and an F. The "F" is for the spark timing at Idle. Like I said, you need to see the advance, which will come in when revved, go back and forth, smoothly with the engine rpm change. If the rpm is steady then the timing should be steady.
- zig
- zig
- Motor Head
zig wrote: ok i understand now i dont have a manual been looking for one but i dont know what one to get see the bike is a 1979 kz750 ltd h1 but most parts list for a 1980 it was built in aug. of 1979 and when i bought a carb kit it was wrong needle jet and float needle where way smaller lol so how do you adjust it and what should it be set at
You need the correct ones, Needle Jet or Jet Needle. One is the Orifice, the other the tappered needle. Then the float needle which meter fuel into the bowls, along with the seat for it, they come in different sizes. It really sounds as though you need the proper cab kits, if you are lean on fuel it will run hot. Jet sizes, fuel level in the bowls etc all play into this.
Look here on KZR, "File Base" Non specific models. It will have all kinds of carb info. It right at the top, far right of the screen when you're logged in.
- bountyhunter
- Thank you received: 337
