Help with motor Yr. KZT10AE023262
- adam90xj
- Thank you received: 797
Year & Model '77 KZ1000-A1
Color(s) (1) Diamond Wine Red
(2) Diamond Sky Blue
Frame No. Range (Japan MFR)
KZTOOA000101 - 026623
(USA MFR)
KZTOOA500001 - 507026
Engine No. Range KZTOOAE000101 - 41170
Engine No. Location RH top crankcase, below carburetor
Cylinder Mark 1.015L
Cylinder Mark Location Front RH corner
Engine Type 4-stroke, 4-cylinder, DOHC, Air cooled
Bore X Stroke 70.0 X 66.0 mm
Compression Ratio 8.7:1
Maximum HP 83 at 8000 rpm
Maximum Torque 8.1 kg-m at 6500 rpm
maybe they used an engine from a chain drive model like this one and put the "shaft"to it :pinch: ,so to speak .
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- adam90xj
I was under the assumption that this was in the ballpark of 81-83. It has Mikuni BS34 CV style carbs with a single main jet, and a single fuel pilot jet. They have vertical oriented fuel screws on the top. The mains are 127 and the pilot are 37.5
- Mcdroid
- Gone Kwackers
adam90xj wrote: Now I'm really confused. This is an 1100 motor. It is shaft drive and no kickstarter. Did they put kz1100 engines in a ZN1100? I see ZN1100 specific engine options as far as carb choices etc.
The mid-1980's was the time of the great change for all the Japanese manufacturers...all were going to water-cooled motors and radically changing body styling. In Kawasaki, the early GPz bikes (ZX750A and ZX1100A series, for ex.) still used the earlier KZ-style motors (which is reflected by the earlier KZ numbered VIN's). Similarly, The KZ1100A and KZ1100L series were replaced by the ZN1100 series, which used KZ1100 motors with KZ VIN's. KZ motors were still being used in the ZX750 line through 1988 despite that the KZ750 line ended in 1984. The air-cooled ZN series lasted two years and was fundamentally replaced by the V-twin.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
