valve shims
- RustedAce
08 Jul 2012 21:06 #534737
by RustedAce
81 kz 750 ltd
valve shims was created by RustedAce
Looking to go over valves this week. Wondering if anyone knows where to get shims individually. Im Lancaster pa area. Its on a 81 kz750 also looking for any hints or tricks looks pretty strait forward on it.
Thanks
Thanks
81 kz 750 ltd
- Thank you received: 2098
08 Jul 2012 23:42 #534761
by Patton
www.z1enterprises.com/catalog.aspx?pid=KZ750-E2-1981-EN1
Carefully follow FSM procedure.
As many have experienced, a mistake can easily result in bent valves.
Replied by Patton on topic valve shims
Z1 Enterprises (usually ships same day)RustedAce wrote: ...where to get shims individually...81 kz750...any hints....
- bountyhunter
- Thank you received: 337
09 Jul 2012 02:04 - 09 Jul 2012 02:08 #534775
by bountyhunter
Sometimes if the local dealer is not a complete POS, he will let you swap him your old shim for a different size with a $5 bill on the side.....
Of course, finding a dealer who is not a POS is like trying to find an honest politician. Try chatting up the kid at the parts desk or one of the mechanics.... they may take pity on you. YMMV
Replied by bountyhunter on topic valve shims
The 750 twins take a 32 mm shim which is no longer made anywhere. Z1 Enterprises stocks some used ones when they can get them, so specific sizes are always iffy. People sell them on ebay sometimes for about $15 apiece plus shipping.RustedAce wrote: Looking to go over valves this week. Wondering if anyone knows where to get shims individually. Im Lancaster pa area. Its on a 81 kz750 also looking for any hints or tricks looks pretty strait forward on it.
Thanks
Last edit: 09 Jul 2012 02:08 by bountyhunter.
- Motor Head
- Thank you received: 391
09 Jul 2012 10:11 #534808
by Motor Head
Replied by Motor Head on topic valve shims
I believe these for a Fiat 124 engine are 32mm. You can ask them.
www.international-auto.com/cylinder-head...dual-valve-shims.cfm
- bountyhunter
09 Jul 2012 16:09 #534860
by bountyhunter
If you use a different type, make sure they are hardened shims or they won't last too long.
