- Thank you received: 540
Clutch push rod 750B twin
- MFolks
- Cdiver
1978 KZ750 Cafe Racer
- Thank you received: 2829
Cdiver wrote: Looks like there is an 1/8" ball bearing that is supposed to be between the set screw and push rod. I am missing this. Might be the problem?
The ball bearing does not go between the set screw and push rod. It goes between the push rod and clutch spring plate pusher. Ed
- steell
jonnybravo wrote:
a half an inch too much amigoCdiver wrote:
Cdiver wrote:
bountyhunter wrote: I think it pulls out but there's a round ball bearing in there somewhere that often gets lost and inspires "Why doesn't My Clutch Work Anymore?" threads.
So now what? Remove the cover behind the sprocket and put the ball bearing back in, then replace cover?
I only pulled the rod out no more than half an inch.
do a search there's only about 50 threads on this
Nonsense! It's a 750 twin, the worst that can happen is the ball will fall out on the floor, and that's only if the rod is completely removed.
+1 What possible harm can pulling the clutch rod out 1/2" cause? None that I can think of.
- bountyhunter
- Thank you received: 337
It is possible to get the release assembly together wrong if you take that apart.... guess how I know that. :laugh:
- Cdiver
- Cdiver
650ed wrote: I wouldn't be pulling any of that stuff apart; why do that? I would just clean and lubricate the clutch release mechanism, adjust the clutch properly (using instructions from the Kawasaki Service Manual) and ride the thing. Adjusting the clutch involves more than just the nut at the lever and the mid cable adjuster, but it is easy to do. Unless you pulled the clutch rod all the way out and laid the bike on its left side the ball is still where it belongs. What makes you believe it fell into the tranny and how could it??? I honestly think you are making this into a huge project when there really is no problem to solve. When is the last time you actually rode the bike? If it has been a while your clutch plates may just be stuck together. If so this is really easy to fix - no tools or disassemble required. You have not hurt anything yet, but start pulling stuff apart and you increase the odds dramatically. Ed
I did not pull the lever all the way out and no way I laid it over. Just going by what some of the guys on here have said. I by no means want to take it apart. Just thought that's what I'd have I do to fix it. Been riding the bike for the last few months. I guess I'm just not adjusting it correctly. I don't have a manual, by any chance do you know where I can find one to download (free would be nice). 1978 KZ750B
Thanks for your input. I'm pretty new to the bike machanic work so this forum really helps.
- damarble
- Thank you received: 13
That's what I thought too. Mine was bent and worn so bad the seal leaked, I replaced it with a NOS rod off ebay. Super simple job, pulled old out, push new in.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- osage
- Thank you received: 4
If you can't find it let me know and I can snail mail it to you.
1976 KZ750B1
1982 KZ750H3
