oil from crankcase breather tube
- battlecat
07 Jul 2012 20:30 #534557
by battlecat
'79 Kz650b3 RAT. Used to ride an immaculate cb750. it was boring.
oil from crankcase breather tube was created by battlecat
I've got oil spewing from my crank case breather tube. What could be causing such a dirty situation....?
- 4TheKZ1000
- Visitor
07 Jul 2012 21:00 #534561
by 4TheKZ1000
Replied by 4TheKZ1000 on topic oil from crankcase breather tube
over filed crankcase
over heating
over heating
- Thank you received: 2098
08 Jul 2012 00:14 - 08 Jul 2012 00:15 #534587
by Patton
Replied by Patton on topic oil from crankcase breather tube
Another possibility -- oil in crankcase has become contaminated by gasoline having entered the crankcase.
It's time for a sniff-test and physical examination of the crankcase oil.
Last edit: 08 Jul 2012 00:15 by Patton.
- RonKZ650
- Thank you received: 240
08 Jul 2012 01:03 #534593
by RonKZ650
Replied by RonKZ650 on topic oil from crankcase breather tube
Or just a worn out engine. A 35 year old engine with probably 35 yr old valve seals hardened to plastic, ect, blowby will push out oil. Best to keep oil level to the low mark on a worn engine to minimize oil blow.
