KZ 750 wont fire on cylinders 1 and 3.
- olthoff
07 Jul 2012 00:30 #534386
by olthoff
KZ 750 wont fire on cylinders 1 and 3. was created by olthoff
I have spark and fuel on #1 cylinder tho I dont know if it is getting past the carberator. Just changed spark plugs. carbs look like a nightmare to take off and clean.
- lushbaugh
- everybodys a pro......
- Thank you received: 35
07 Jul 2012 00:46 #534390
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic KZ 750 wont fire on cylinders 1 and 3.
Be more certain and clear on symptoms , by yoir title ill say ita either a coil, or point side or pick up on one side went bad or wiring between. Im drunk as ten mofos but check signal from points or pickup, if nothing, you know if you get signal from the ignition source "points or pickup" , check continuity on the wires, it thats sound, its a coil.if this dont make sense sell me your bike for ten dollars lol. Best of luck!
- osage
- Thank you received: 4
07 Jul 2012 00:59 #534396
by osage
1976 KZ750B1
1982 KZ750H3
Replied by osage on topic KZ 750 wont fire on cylinders 1 and 3.
First off welcome to the forum.
I'll second more info and you can add year and model to your profile. Is the spark weak or blue. Old bikes with factory coils do cause problems.
Do you have battery voltage at the coil? I know I lost alot of voltage between battery and coil before I got the connections cleaned up. Mine was about 10volts at the coil and I had weak sparks.
I'm sure others will be along to help.
1976 KZ750B1
1982 KZ750H3
