84 KZ550 Oil Plug Spinning
- acidone
- 84 KZ550
My problem is when I try to unscrew the oil drain plug it just spins like maybe its on a bad thread or something? I didn't try to much because I didn't want to make matters worse. It's not leaking any fluids atm. So what do I do to get this bolt out, suggestions? Or could I let it drain by removing the filter and replacing it, which i intended to do anyway.
Thanks,
-A
- Thank you received: 2098
acidone wrote: ...having an issue after a recent oil/filter change; when I would go over large bumps or rail road tracks my Oil Light would flicker on and off. It didn't do that before the change. I used the correct amounts of oil for a filter change and used 10w40 in the bike. So after reading around I thought I would drain it again and go up to a 20w50 and replace the filter again.
My problem is when I try to unscrew the oil drain plug it just spins like maybe its on a bad thread or something? I didn't try to much because I didn't want to make matters worse. It's not leaking any fluids atm. So what do I do to get this bolt out, suggestions? Or could I let it drain by removing the filter and replacing it, which i intended to do anyway....
Likely that the female threads in the oil pan drain plug hole are partially stripped, and the drain plug's male threads are likely undamaged.
Am doubtful that a new drain plug would be of any help, and suspect that it would probably also spin just like the existing plug screw.
Would repair to achieve a tight fitting drain plug.
One option is to replace the plug with a larger self-tapping drain plug, which may be available at a local automotive supply such as AutoZone or NAPA.
Another option would be to replace the oil pan.
Used oil pans are available and relatively inexpensive.
Oil plug fitment isn't related to function of the oil pressure warning light, unless enough oil leaks out to activate the light.
Would suspect loose or dirty (corroded) wire connections at the oil pressure switch might be causing the oil light to flicker.
- wireman
- Thank you received: 299
- Thank you received: 2829
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- pete greek1
- Thank you received: 185
- loudhvx
- Thank you received: 1616
There are siphon gadgets that will such the oil out through the filler.
But you really should fix/replace oil pan as others said.
Also, you may want to try a new oil pressure switch before switching to higher viscosity oil. Or play with the wiring like Patton said.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- acidone
- 84 KZ550
-A
- Thank you received: 1656
