- Thank you received: 36
Pulling the rotor on 650 - how?
- faffi
06 Jul 2012 17:53 #534297
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Pulling the rotor on 650 - how? was created by faffi
Must have made a poor search since I couldn't come up with anything, but is there a wheel axle or something on the bike that can be used to pull the rotor on a KZ650B1? Also, do I need Loctite on the rotor/crank interface and/or bolt when refitting? There's no Loctite on the bolt now.
Finally, how much should I torque the retainer bolt? My Haynes doesn't tell, not does it tell how to remove the rotor. Useless
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- Thank you received: 2829
06 Jul 2012 18:44 #534310
by 650ed
Replied by 650ed on topic Pulling the rotor on 650 - how?
I haven't had time to look it up, but take a look at the link to see if instructions are in Kawasaki Service Manual. Ed
www.scribd.com/doc/48655900/Kawasaki-KZ-...B1-77-Service-Manual
- faffi
06 Jul 2012 19:03 - 06 Jul 2012 19:05 #534314
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Replied by faffi on topic Pulling the rotor on 650 - how?
Thanks, Ed. Had a look and it said to use a special tool, which I believe is basically just a big/thick bolt with the right theads. But at least I know the torque settings now
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Last edit: 06 Jul 2012 19:05 by faffi.
- RonKZ650
- Thank you received: 240
06 Jul 2012 19:07 #534317
by RonKZ650
Replied by RonKZ650 on topic Pulling the rotor on 650 - how?
The 650 used two different threads on what tool you need to remove the rotor. The chrome bolt going down through the triple tree below the handlebars works on some KZ650s, others a rear axle is what you need. Regardless it's always a bear of a job to get that thing loose most the time.
- faffi
06 Jul 2012 19:14 #534321
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Thanks, Ron! BTW, there is some surface rust on the rotor, could this impact its performance? Can I sand it off with 400 grit or finer?
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- faffi
10 Jul 2012 06:12 #535014
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Well, all the possible bolts (wheels, swingarm, steering stem) are 16 mm and will fit the "new" F1 engine's flywheel, but the old flywheel/rotor require an 18 mm x 1.5 bolt. Bought one at the local hardware store, 50 mm long and standard 8.8 quality. It cost $16.50! Think I'll place it in a padded box after use
1977 KZ650B1
1980 F1 engine
B1 Points ignition
