Swap clutch cable on 78 750 twin
- Cdiver
06 Jul 2012 11:13 #534245
by Cdiver
1978 KZ750 Cafe Racer
Swap clutch cable on 78 750 twin was created by Cdiver
Need to change my clutch cable. Just wondering if anyone has any pointers. Haven't dove into it yet, but I'm hoping it's pretty straight forward. Any help would be appreciated. Thanks
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
06 Jul 2012 15:07 #534274
by Rainman
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Replied by Rainman on topic Swap clutch cable on 78 750 twin
Cdiver, it is fairly simple.
Loosen adjuster in middle of cable
Remove cable at top
Remove cable at bottom (foot peg, shifter and sprocket cover come off). Tension springat bottom inside case is a must have, don't loose or leave out at reassembly.
Remove cable (take note of routing)there are two cable clips to frame.
Routing cable before reattaching either end, gives the most routing flexability.
Lube cable and grease clutch rod end before reassembly.
Inside sprocket cover (if you have not been inside yet)
If you get the urge to test the starter after rebuilding it, do yourself a favor and pull the plug wires so it won't start and throw oil from the flywheel all over the place.
I keep an old clutch cable under the seat, just in case. It can be changed on the side of the road with the tools in the tool kit.
Good luck,
Jim
Remove cable at top
Good luck,
Jim
Jim
Quincy,IL
