- Thank you received: 4
are these washers supposed to be here?
- KZ1000inaus
- Luminous Red KZ1000 A2
But on looking at the Kawasaki diagrams it seems they shouldn't be there (unless i just can't see them). The pic shows the one that's left. They sit on the bottom and look a little home made.
Are they supposed to be there? if not are they a known modification?
Attachment UpperCam.jpg not found
- Garn
- Thank you received: 13
So, the both sides are made up of two rubber mounting block (a bottom and top) both are different, a bottom plate and a top plate, both different as the bottom has smaller holes, and two dowel pieces with a larger head to the top.
I'll have a look tomorrow to verify my memory. [See slight correction below]
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- jonnybravo
- Banned
- Thank you received: 18
- Motor Head
- Thank you received: 391
- jonnybravo
- Banned
yes check that screen, an excellent ideaMotor Head wrote: Pulling the Sump would be a good Idea anyway, as you already have the Top off, and you can clean all the Gunk out. Make sure there is nothing stuck in the oil pick up screen, see if there is any metallic debris, etc.
- RonKZ650
- Thank you received: 240
- Garn
On your model the two plates have 6mm clearance holes on each side and both top and bottom are the same.
As Ron says, the rubber dampers have steel plates built in to them, however, this vulcanised joint does separate leaving the plate and rubber block as individual items. Do check to see if there is not a plate on the rubber already.
RegardZ.
Sydney Australia
- KZ1000inaus
i'll get the sump off tomorrow and see if i can find it as i can't see it from the top to retrieve it
- KZ1000inaus
by the way i ordered new rubbers from Z1enterprises and they don't have the metal on them it's just rubber.Garn wrote: I have a slight correction to my original post. Looking at the Model Z1000-A2, I realize I am incorrect about the lower plate having smaller holes.
RegardZ.
- jonnybravo
- Banned
- KZ1000inaus
and it was in there.. wooo hooo!!
plain sailing from here on in then..
rebuild next week.. or when the parts turn up anyway..
