Hard to get into neutral
- 80kz550A1
05 Jul 2012 23:47 - 05 Jul 2012 23:48 #534153
by 80kz550A1
Hard to get into neutral was created by 80kz550A1
Okay so recently my bike has been hard to get into neutral. I have to really pull up on the shifter. Or sometimes it will go right in. Could this be something to do with the clutch? My bike does have some rattling at idle but I assumed it was the primary chain.next thing I want to do is install a manual cam chain tensioner and check cam clearances.
Last edit: 05 Jul 2012 23:48 by 80kz550A1.
- Tomolu5
- Thank you received: 45
05 Jul 2012 23:52 - 05 Jul 2012 23:53 #534154
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic Hard to get into neutral
-check valve clearences
-check and adjust clutch(cable and rod)
-probly wasting your money on the tensioner
Mine:
Last edit: 05 Jul 2012 23:53 by Tomolu5. Reason: typo
- MFolks
- Thank you received: 540
05 Jul 2012 23:53 #534155
by MFolks
Replied by MFolks on topic Hard to get into neutral
What grade and type of engine being used? Most "Car Oils" are not kind to wet plate motorcycle clutches as they have friction modifiers. The popular oil to use is the Shell Rotella, or oil that is rated to use in a Diesel engine.
- 80kz550A1
06 Jul 2012 00:16 #534167
by 80kz550A1
Replied by 80kz550A1 on topic Hard to get into neutral
I am using rotella 15/40. Also I just got a new tach cable from z1 enterprises (mine vibrated loose and the cable fell out. My tach works but jumps around, makes a weird whirring noise above 1500 rpm and won't go higher than 7000. Oh yea I just got bar end mirrors from z1 enterprises and they are crap. I stripped out the threads while tightening the mirror. Definelty not worth the money.
- 80kz550A1
07 Jul 2012 15:34 #534523
by 80kz550A1
so i adjusted my clutch cable and the problem seems to have gone away.
- kaw-a-holic
- Thank you received: 249
07 Jul 2012 16:58 #534535
by kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Replied by kaw-a-holic on topic Hard to get into neutral
I can not express how important it is to oil cables they will leave you stranded if not maintained. If done properly you will dump oil in from the top until it comes out the bottom then hang for a bit to drain. Don't forget to grease the clutch actuator.
Jon
1977 KZ1000a1
Mesa, AZ
