Clutch springs recommended torque?
  • SeattleKZ
  • SeattleKZ's Avatar Topic Author
05 Jul 2012 12:37
#534008
While I was installing a barnett clutch and springs in my 1977 KZ1000 yesterday I broke the clutch basket. The bolt never felt like it was tight. You can clearly see the threads are not striped. If anybody has this part I need a new one and also when installing Barnett springs what do you torque the bolts to? I don't wanna do this twice.
  • gixxerfiend
  • gixxerfiend's Avatar
Re: Clutch springs recommended torque?
05 Jul 2012 12:49
#534010
the torque is very light on spring bolts, they will never feel tight because they never bottem out on anything. most modern day bikes are around 7 lbs. 2 weeks ago I watched a buddy break a spring bolt with a torque wrench set at 10 lbs. 2 more snapped as we were taking then out to pull the basket to extract the first broken bolt. these are definatly bolts that have to be done by spec. the hour and a half job ended up taking 12 hours :pinch: I cant count the buddies that I have known that have broke spring bolts or messed up baskets on both hands
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
  • gixxerfiend
05 Jul 2012 12:53
#534012
from what ive read you need 78-inch pounds
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
  • bluezbike
  • bluezbike's Avatar
05 Jul 2012 13:47
#534027
I have one, where are you in Seattle? PM me with your phone and we'll see what we can do
Bluezbike
79 KZ 1000 LTD
  • SeattleKZ
05 Jul 2012 13:51
#534028
bluezbike wrote: I have one, where are you in Seattle? PM me with your phone and we'll see what we can do
Bluezbike
PM sent :)
