- Thank you received: 12
Is this the rotella T from walmart you guys use?
- apbling
04 Jul 2012 19:21 #533870
by apbling
Is this the rotella T from walmart you guys use? was created by apbling
Hi all,
Hope your 4th of July is going well!
I have a question. I've been looking at the rotella T at wal mart that some people here use. I just want to make sure this is the same formulation you all use. I don't want to have to clean my clutch plates off because I got the wrong blend!
thanks,
Andy
thanks,
Andy
- RonKZ650
- Thank you received: 240
04 Jul 2012 19:41 #533875
by RonKZ650
Replied by RonKZ650 on topic Is this the rotella T from walmart you guys use?
Yes, that is good 15w40. Other guys use the 5w40 synthetic, they also have 10w40, and 10w30 semi- synthetic, but walmart only carries the 10w30. All these work fine. I don't like 5w40 though because the 5w shears real quickly. 10w40 is recommended and I wish was easier to buy as that works all year around. 15w40 doesn't work in cold weather.
- Thank you received: 1656
04 Jul 2012 20:26 - 23 Feb 2013 16:05 #533881
by martin_csr
Last edit: 23 Feb 2013 16:05 by martin_csr.
- Thank you received: 2829
04 Jul 2012 22:01 #533899
by 650ed
Replied by 650ed on topic Is this the rotella T from walmart you guys use?
I don’t use that particular oil, but if you look at the end of the text in the rectangular block on the back of the container you will notice that it states it meets JASO-MA service requirements. Based on that I would say it should work just fine for your clutch because the JASO-MA standard is specifically written to address wet clutch requirements. Ed
- dejavoodo41
- Thank you received: 14
04 Jul 2012 23:41 #533918
by dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Replied by dejavoodo41 on topic Is this the rotella T from walmart you guys use?
I've been using Rotella T 15W40 for the last 3 years and have had zero problems with it. Prior to using Rotella I was using Castrol Actevo and my bike seems to shift better with the Rotella. The only oil that I've used that shifted smoother in my bike was Repsol Moto Sport 4T but that stuff was almost 4 times the price of the Rotella. You really can't go wrong with it. I even run it in my cars.
- gixxerfiend
05 Jul 2012 00:09 #533925
by gixxerfiend
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
Replied by gixxerfiend on topic Is this the rotella T from walmart you guys use?
Ive used the synthetic rotella t6 in every bike that ive owned (all modern day sportbikes). Most recent bike is a 2006 gsxr 1000. Ive put on about 15k miles on in the last year, all very hard riding no commuting. Mountain runs, Dragstrip, very long wheelies and even trackdays. my last bike (gsxr 750) even had the drainbolt come out and was rode for about 15-20 seconds dry before the oil light came on and I shut it off. I got another drain bolt, filled with oil and put another 13k on it without any clutch or engine problems before i sold it. Also know a few other hard riding guys that have ran it for years with no clutch problems. I would love to run it in the kz but dont know what synthetic would do to a 35 year old bike that has more then likely had conventional its whole life. Ill prolly go with the 15w40, thx for asking so i didnt have to
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
05 Jul 2012 08:45 #533968
by 650ed
Synthetic motorcycle oil works great in the KZ650. I've been using Mobil-1 Racing 4T 10W40 in mine for the past 6 years. Just make sure whatever oil you use says on the bottle that it meets the JASO-MA standard. That is the standard for lubricants for use with wet clutches. Also, you may want to consider using K&N oil filters; the KZ650 uses #KN-401. Dennis Kirk carries them. Ed
